Here is a straightforward breakdown of two new products we just finalized and added to our lineup for the 4th Gen Tacoma. Both items are currently in stock and ready to ship.
1. TRUMGETA Heavy-Duty Aluminum Roof Rack (2024+ Tacoma)
We designed this rack to maximize roof load capacity while minimizing the common issues of wind noise and excess weight.
2. TRUMGETA Slide-Out Truck Bed Cargo Tray
This bed slider is engineered to give you quick access to gear at the front of your truck bed without needing to crawl inside.
Forum Discount
For members of this community looking to pick up either of these new releases, you can use the code below at checkout for a forum-exclusive discount:
- Construction: All-aluminum frame to keep the overall weight low while maintaining structural rigidity for rooftop tents and heavy gear.
- Design: Low-profile and contoured specifically to match the 4G Tacoma roofline, which helps reduce drag and highway wind whistle.
- Mounting: Features standard T-slot crossbars, allowing you to use existing hardware to mount recovery boards, cases, or lights.
- Product Link: TRUMGETA Heavy-Duty Aluminum Roof Rack
- Operation: Built on heavy-duty bearing tracks for a smooth slide even when fully loaded. It includes a multi-stage locking mechanism to keep the tray secure when fully closed, partially open, or fully extended on the trail.
- Tie-Down Versatility: Features integrated perimeter rails and tie-down points across the deck, allowing you to easily strap down coolers, toolboxes, and camping gear to prevent shifting during transit.
- Fitment: Engineered to fit mid-size trucks like the 4G Tacoma, as well as full-size truck beds, maximizing usable bed floor space.
- Product Link: TRUMGETA Slide-Out Truck Bed Cargo Tray
Forum Discount
- Code: Forum10 (10% OFF)
