Alternatives to outdoor carpet for exposed plywood shelf I'm going to put in my bed?
rellis
Richard
Colorado Springs, CO
2025 Toyota Tacoma Trailhunter, 2007 Lexus GX470, 1993 Toyota MR2 Turbo
Title pretty much says it. Just took delivery on a 2025 and I'm going to utilize the little insets on the bedsides install a couple of boards from side to side and then put some plywood on top of that. Basically just to give me two levels of storage, one of which is out of sight and mostly out of the weather.
I've done something similar in the past and installed outdoor carpet to cover the plywood surface And to provide a relatively soft surface to place things on that I don't want getting scratched up by the bed itself.
Curious as to other options anyone may have used?
Again, looking for something kind of soft. Otherwise I would just get a decent grade of exterior plywood and paint it
Thanks in advance
trailhunger
2024 TH
You can order sheets of BedRug. That stuff is amazing can withstand years of outdoor use $
& abuse.
Straight phenolic sealed plywood I like marine grade WISA Hex Ultralight
rellis
Richard
& abuse.
Bedrug! Great suggestion. Totally forgot about it, last used it probably 25 years ago. Thanks!
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB Ice Cap White, 2023 Acura Integra 6MT Apex Blue Pearl
I wonder if you could use bedliner spray.
lauren01
Lauren
Ventura, CA USA
I was thinking this same thing, but wasn't sure if it would adhere to wood properly
Same thoughts here too. Might have to put some plastic over the wood… just depends on the look desired, the function desired… and how much pain and expense to get it dialed in.
rellis
Richard
& abuse.
I've looked but so far I can only find precut sets for specific trucks. The Bedrug site itself seems to direct you to Amazon for all their (precut) products.
Do you know specifically where simple oversized rectangular pieces, of linear feet off of a roll, can be purchased?
