🏷️20% OFF Bed Rail Caps and Bed Mat Set (5FT) | xipoqix
xipoqix_official
Jackie
China
If you use your truck for hauling things, adding an extra layer of defense can make a big difference. Our Bed Rail Caps and Bed Mat Set helps shield the metal edges and the bed floor from daily wear and tear. Now you can lean cargo against the rails without worrying about scratching the edges. It also does a good job of covering up those gaps where dust and road grime tend to accumulate, making cleanup easier after a trip.
Made from flexible TPE rather than rigid plastic, the protectors absorb impacts and resist temperature changes, whether it’s cold winters or hot summers. The textured finish is also quite practical for hiding minor scuffs that naturally happen over time. The whole setup is water-resistant, so you can easily rinse it down when it gets dirty.
This set is designed specifically for the 2024-2026 Toyota Tacoma. Installation doesn't require drilling or special tools—just secure the caps with the adhesive tape and place the mat in.
If you are thinking about upgrading your setup, we have a special 20% OFF discount running for members here right now.
📅 Date: Jan. 20, 04:00-Feb. 2, 23:59 (PST)​
🏷 Code: 4349MWBZ​
xipoqix_official
xipoqix_official
Jackie
China
We're now offering more options to suit your setup!
▼ Trunk Mat + Tailgate Mat Combo:
Perfect for those who want more comprehensive protection for their truck bed.​
Truck Bed Rail Caps:
Need just the side protection? You can grab the truck bed rail caps separately here.​
