2ndGen2TrlHntr
Alex
Denver, CO
2024 Trailhunter Bronze Oxide; 2018 Audi S5 tuned
I'm working on a camper build so I took some pretty detailed measurements of the 2024 Tacoma 5' Off-Road bed! Sharing in case it helps someone else!
Solid work on the detail. I just sent this to one of the shops that's doing part of my buildout for my Trailhunter to be (once it arrives after QC hold).
Benen
Ben
Netherlands
Toyota Tundra
I am interested in a 2024 Tacoma but may have a strange question in this context. Here in the Netherlands, the government determines whether a pick-up can be used commercially based on the dimensions of the pick-up box. One of those measurements is the distance from the center of the rear axle to the rear of the cabin, the rearmost point of the cabin. I know the 6ft is no problem but I would prefer the 5ft. Is it a lot to ask to measure this size for me? Please note that they measure it accurately to the centimeter. Thank you in advance. I am very grateful!!
andrewleader
andrewleader
Andrew
Washington State
2024 Tacoma Off-Road 5' Automatic with Stabilizer Dsconnect
I'm not quite sure which measurement you're talking about, could you annotate a picture? Is it what I drew here, where if you took an imaginary line straight up from the center of the rear axle and then measured horizontally to the back outside of the cab?
2024 Tacoma 2024 Tacoma (4th Gen) - 5' Foot Bed Measurements - Detailed Dimensions Screenshot 2024-10-18 114055
I have my 5' Tacoma now, so I'm happy to try measuring things, but I'll need ya to be much more specific! (Yes this photo is a 6' one, I just found one online of a side view to annotate for clarity)
  • Like
Reactions: WOW
andrewleader
andrewleader
Andrew
Washington State
yes exactly that size! Thanks a lot!
I can't promise centimeter-level accuracy (visually guestimated that imaginary line from center axle up), but I measured 23.125", you can see the attached photos. I'd give it a margin of error of 1 or 2 inches in either direction. Hope that's enough to be helpful!
2024 Tacoma 2024 Tacoma (4th Gen) - 5' Foot Bed Measurements - Detailed Dimensions IMG_7049
2024 Tacoma 2024 Tacoma (4th Gen) - 5' Foot Bed Measurements - Detailed Dimensions IMG_7047
writemccaffrey
Michael
Oakland, CA
2026 Tacoma SR5 (4x2)
Does anybody know the height from the top of the bed rail "nibs" in this picture to the top of the cab/roof at the centerline/highest point? I get about 20" but that's with a measuring tape + some hefty "eyeballing" to account for peak in roof, etc.
I custom-made an aluminum extrusion rack for my old Maverick that I'm trying to repurpose but I'll need to order some new uprights that are a tad longer to account for the height difference.
