2024+ Toyota Tacoma Rock Sliders: 3 Must-Have Options
OffRoadUSA.com
offroadusa.com
'22 Tacoma
If you wheel a 2024+ Toyota Tacoma and plan to do more than mall crawling, rock sliders move from “nice-to-have” to essential gear. At OffRoadUSA.com, we hand-pick rock sliders that can actually save your rocker panels, double as usable steps, and stand up to real trail abuse—not just look tough in photos.
In this guide, we break down what rock sliders do, how to choose the right style for your Tacoma, and where three of our favorite options shine: Cali Raised LED Trail Edition, Cali Raised LED Step Edition, and CBI Overland Bolt-On Rock Sliders.
What Rock Sliders Actually Do
Rock sliders are frame-mounted armor designed to take the hit instead of your Tacoma’s doors, rocker panels, and lower body.
  • They act as a sacrificial barrier between rocks, stumps, ledges, and your sheet metal, so the slider gets scraped—not your truck.
  • Most heavy-duty sliders are strong enough to support the weight of the vehicle so you can use them as a jacking point for recovery or to change a tire.
  • Many designs double as side steps, which is huge if your Tacoma is lifted or you have kids and passengers climbing in daily.
On a 4th Gen Tacoma, the rockers and doors sit relatively low and are extremely expensive to repair or replace. A hard hit on a rock without sliders can mean bent pinch welds, crushed doors, or even frame-adjacent damage that affects alignment. Rock sliders are cheap insurance compared to body work.
Key Features to Look For on a 2024+ Tacoma
Not all rock sliders are created equal. From OffRoadUSA.com’s perspective, here’s what actually matters when you’re shopping for your 2024+ Tacoma.
Tubing Material and Wall Thickness
  • Most premium Tacoma sliders use 1.75-inch DOM round tubing with a wall thickness around 0.120 inches, which balances strength and weight.
  • DOM (Drawn Over Mandrel) tubing is stronger and more impact-resistant than basic HREW, which is why you’ll see it on higher-end options from Cali Raised LED and CBI Offroad Fab.
For a truck that will see real rock contact, trusting DOM construction is smart; it’s designed to resist crushing and bending under load.
Mounting Style: Fully Bolt-On vs. Weld-On
On a new Tacoma, weld-on sliders are overkill for most owners and complicate resale. The 2024+ platforms we feature are all designed as fully bolt-on, using factory frame locations:
  • Cali Raised Trail Edition rock sliders use a 100% bolt-on design with Grade 8 hardware and require no frame cutting or welding.
  • Cali Raised Step Edition rock sliders for the 2024+ Tacoma follow the same bolt-on concept, making install accessible in a driveway or home garage.
  • CBI’s Overland Bolt-On sliders are exactly what the name says—bolt-on only—with an install time of roughly about an hour once the truck is on stands or a lift.
Bolt-on is the sweet spot for modern Tacomas: strong enough for trail duty, easy to install, and easy to remove or sell later.
Angle and Kick-Out vs. Straight
Slider “angle” refers to how far they sit away from the body and how much they tilt up toward the rocker.
  • Flat or 0-degree sliders behave more like steps, keeping a broad, horizontal surface that’s easy to stand on.
  • Angled sliders (around 15–20 degrees) tuck up closer to the body and provide better clearance off-road when pivoting around rocks or ledges.
A kick-out flares the rear portion of the slider outward:
  • It helps “bump” the rear of the truck around obstacles instead of letting rocks chew into your bedside.
  • It also doubles as a larger rear step, handy for accessing the bed or roof rack.
Cali Raised and CBI both let you choose kick-out vs. no kick-out and angled vs. flatter setups, so you can dial in how trail-focused you want your Tacoma to be.
Top Plates and Step Function
For daily-driven trucks, top plates are a game-changer.
  • Perforated or dimple-die top plates provide grip in rain, snow, or mud and create a wide, secure stepping surface.
  • Cali Raised Step Edition sliders add an integrated filler/top plate specifically to improve everyday usability while maintaining full trail capability.
  • CBI’s Overland sliders offer a flat top-plate variant that gives you that step-like feel with a clean, armored look.
If your Tacoma doubles as family hauler and weekend warrior, step-style sliders are often the best compromise.
Cali Raised LED Trail Edition Rock Sliders (2024+ Tacoma)
Trail-Focused Protection, Daily-Driver Friendly
Cali Raised LED’s Trail Edition Rock Sliders for the 2024+ Toyota Tacoma are built for drivers who spend serious time on the trail but still need a clean, functional look for daily life.
These sliders are:
  • Custom-made for 2024+ Tacoma Double Cab configurations, with options for short bed and long bed.
  • Crafted from American 1.75-inch DOM tubing with 0.120-inch wall thickness, giving them the strength to handle full vehicle weight and real rock impacts.
  • Available with or without a rear kick-out, so you can prioritize clearance or rear protection/step space.
Construction and Finish Options
From a builder’s standpoint, these Trail Edition sliders pack in value where many brands start upcharging:
  • The sliders use heavy-duty DOM tubing and are designed to be 100% bolt-on using Grade 8 hardware, with no frame modification required.
  • Kick-outs are included as a configuration choice, not an extra-cost add-on, making them more accessible for budget-conscious builds.
  • Finish choices include raw steel, powder coat, or bedliner-style coating, giving you options for DIY painting, maximum corrosion resistance, or a rugged textured look.
This flexibility lets you match your Tacoma’s aesthetic—from clean OEM-plus to full overland rig.
Real-World Use and Fitment Notes
Cali Raised emphasizes that these sliders are strong enough to jack from and built for serious off-road use, not just appearance. The design focuses on:
  • Guarding the underside and rocker area while still leaving enough access around drains and factory mount points.
  • Keeping weight reasonable while using DOM tubing and gusseting where it matters most.
Important fitment considerations:
  • These Trail Edition sliders are designed for 2024+ Tacoma Double Cab trucks.
  • They will not fit TRD Pro, Trailhunter, or hybrid models, due to differences in underbody layout and components.
If you’re building a trail-leaning Tacoma and want maximum rocker protection with an angled, tucked profile, the Trail Edition is an excellent choice from our catalog.
Cali Raised LED Step Edition Rock Sliders (2024+ Tacoma)
Built for Daily Driven, Family-Friendly Tacomas
The Step Edition Rock Sliders from Cali Raised LED are aimed squarely at Tacoma owners who split their time between off-road weekends and daily commuting.
Key highlights:
  • Purpose-built for 2024+ Toyota Tacoma, with a 0-degree (flat) profile that works extremely well as a step.
  • Made from the same American 1.75-inch DOM tubing as the Trail Edition, so you’re not sacrificing strength for convenience.
  • Available with kick-out or no kick-out, and with optional filler/top plates that transform them into grippy, all-weather side steps.
From OffRoadUSA.com’s vantage point, these are ideal if your Tacoma is a family rig that still sees fire roads, light trails, and occasional crawling.
Comfort and Convenience Without Compromising Armor
What sets the Step Edition apart is the integrated step functionality:
  • The flat, 0-degree angle keeps the surface horizontal, making entry and exit comfortable for all passengers.
  • The filler/top plate adds a broad, secure area for your foot, which is huge for lifted trucks, kids, or anyone loading gear into roof racks and bed racks.
  • The design still mounts to the frame and uses heavy-duty tubing, so you retain genuine rock protection rather than flimsy running-board behavior.
You get the look and function of proper armor with the practicality of a side step—without resorting to factory running boards that can’t take a hit.
Finish Choices and Install
Like the Trail Edition, the Step Edition sliders are:
  • Offered in raw steel, powder coat, or bedliner finishes, letting you prioritize cost, DIY customization, or maximum durability.
  • Designed for a fully bolt-on installation to the frame using quality hardware, so a competent DIYer can install them at home with hand tools, a jack, and stands.
If you’re honest with yourself and know your Tacoma spends more time in parking lots than on double-black-diamond trails—but you still want real side protection—these are the sliders we’d point you toward first.
CBI Overland Bolt-On Rock Sliders (2024 Tacoma)
Overland-Ready Strength and Style
CBI Offroad Fab is a staple name in the off-road space, and its 2024 Tacoma Overland Bolt-On Rock Sliders continue that reputation. These are designed for owners who want serious, trail-proven protection backed by overland-focused engineering.
Core benefits:
  • Manufactured from high-grade, heavy-duty steel, built to withstand the rigors of repeated rock hits and hard trail use.
  • Strong enough to support the full weight of your Tacoma, letting you safely jack or stabilize the truck from the slider itself during recovery or tire changes.
  • Built as true rocker and undercarriage armor rather than decorative steps, making them ideal for aggressive drivers and technical trails.
Configurable for Your Tacoma and Driving Style
CBI gives you flexibility in how your sliders look and behave:
  • Configured specifically for the 2024 Tacoma in Double Cab, with options for standard (5-foot) or long (6-foot) bed lengths.
  • Available with kick-out or non-kick-out designs, so you can choose between maximum body protection or a more streamlined appearance.
  • Offered in bare metal or black powder coat, giving you the choice of DIY finishing or a ready-to-run, corrosion-resistant coating.
CBI also incorporates a top plate design that serves dual duties:
  • It creates a secure, grippy stepping surface for easy ingress/egress.
  • It adds an extra layer of protection to the upper surface of the slider, which can be critical when sliding along tall rocks and ledges.
Install and Compatibility
CBI’s Overland sliders are engineered for straightforward installation:
  • They use a fully bolt-on mounting system, which avoids cutting or welding and keeps the factory frame intact.
  • Most owners can complete install in roughly an hour with basic tools and a friend or jack to help hold the sliders in place.
One important note: these particular CBI Overland Bolt-On sliders are not compatible with 2WD 2024 Tacoma models. Always verify drivetrain and cab/bed configuration before ordering.
How to Choose the Right Rock Sliders for Your Tacoma
With so many strong options, the real question becomes: which sliders fit your use case best? From OffRoadUSA.com’s perspective, here’s how we’d break it down for a 2024+ Tacoma owner.
Prioritize Your Primary Use
Ask yourself how you use your truck most of the time:
  • Mostly street, some forest roads and mild trails:
    • Cali Raised Step Edition sliders shine here, giving you step comfort and genuine armor.
  • Frequent moderate off-roading with rocks, ledges, and washouts:
    • Cali Raised Trail Edition or CBI Overland sliders are the better fit, thanks to their trail-focused profiles and DOM-based strength.
  • Family daily driver plus occasional hard trail weekends:
    • Step Edition or CBI with a flat top plate strike a perfect balance.
Consider Who Uses the Truck
Remember who actually climbs in and out of your Tacoma:
  • If kids, shorter passengers, or older family members ride often, step-style sliders with top plates will make life much easier.
  • If you often work from the bed or roof rack, having a wide, grippy stepping surface along the side is incredibly practical.
On the flip side, if you’re constantly pushing your Tacoma through tight rock gardens, a more angled, minimalist slider might be worth the trade-off in everyday convenience.
Think Ahead About Build Goals
Your sliders are part of a bigger build roadmap:
  • If you plan on armor (skid plates, bumpers) and bigger tires, match that trail-readiness with robust sliders like the Trail Edition or CBI Overland.
  • If you’re focused on overlanding and travel—racks, rooftop tents, storage systems—step-style sliders make loading and unloading much easier over the long haul.
Choosing the right sliders early can save you from buying twice when your build evolves.
FAQs: Toyota Tacoma Rock Sliders (2024+)
Are rock sliders really necessary for a 2024 Toyota Tacoma?
For anyone taking a 2024+ Tacoma off pavement—especially into rocky or rutted terrain—rock sliders are strongly recommended. The rocker panels and lower doors are vulnerable to damage from rocks, stumps, and ledges, and repairing that body damage is far more expensive than a quality set of sliders.
Sliders also provide jacking points and step functionality, adding safety and convenience even for less extreme use.
What’s the difference between Trail Edition and Step Edition rock sliders?
Cali Raised LED’s Trail Edition sliders prioritize clearance and trail performance with a more tucked, off-road-focused design, often at an angle for better obstacle negotiation.
The Step Edition sliders use a 0-degree (flat) profile with integrated filler/top plates, turning them into comfortable, grippy steps that still mount to the frame and protect the rocker area. Both use 1.75-inch DOM tubing and are fully bolt-on; the choice comes down to whether you want maximum off-road clearance or maximum step usability.
Can I install rock sliders on my Tacoma at home?
Yes. All three highlighted options—Cali Raised Trail Edition, Cali Raised Step Edition, and CBI Overland Bolt-On sliders—are designed as 100% bolt-on systems.
With basic hand tools, a jack or stands, and a helper, most owners can install a set in a few hours or less, especially on a flat driveway or garage floor. There is no welding or cutting of the frame required, which keeps the install DIY-friendly and reversible.
Will rock sliders work with lifted Tacomas and other mods?
In most cases, yes. These sliders are designed around the factory frame and rocker geometry, so lifts, wheels, and tires generally don’t impact compatibility. Where you need to be careful is with specialized trims or underbody changes—Cali Raised Trail Edition sliders, for example, do not fit TRD Pro, Trailhunter, or hybrid models.
Similarly, the CBI Overland Bolt-On sliders are not compatible with 2WD Tacomas. Always verify cab, bed length, drive type, and trim-level notes before ordering.
Do rock sliders help with resale value?
Rock sliders can absolutely help protect your Tacoma’s resale value by preventing rocker and lower-door damage, which is costly and time-consuming to repair. Aftermarket sliders from respected brands like Cali Raised LED and CBI also tend to be desirable to other enthusiasts, which can make your truck more appealing on the used market.
Because the options featured here are bolt-on, they can also be removed and sold separately if you decide to move them to another truck or part out your build.
How do I choose between Cali Raised LED and CBI rock sliders?
Both brands offer high-quality, trail-ready gear for the 2024+ Tacoma, but they cater to slightly different priorities. Cali Raised LED is excellent if you want customizable step vs. trail configurations, multiple finish options, and strong value pricing with included kick-out options.
CBI Overland Bolt-On sliders are a great fit if you lean heavily into overlanding and technical off-road use, want top-plate options and proven full-weight support for jacking and recovery. At OffRoadUSA.com, the decision often comes down to your primary use: daily-driver plus trails (Step Edition), trail-first builds (Trail Edition), or overland/expedition-focused rigs (CBI Overland).
Final Thoughts
When you’re ready to armor up your 2024+ Toyota Tacoma, OffRoadUSA.com is here to help you match your driving style, trim, and build goals with the right rock sliders—so your truck looks aggressive, works harder, and survives the kind of adventures you actually want to take.
Wife bought my 24 TRD
Anthony
Aberdeen Wa
CBI, all the way. Love my rock sliders from them. They are they'll fit well and they function even better..
ixo
Rich
Antioch, CA
2024 Hybrid Tacoma OR Premium
caliraised steps here. love em, even if they took a while to arrive.
