- First Name
- Devin
- Joined
- Jan 13, 2026
- Threads
- 51
- Messages
- 120
- Reaction score
- 41
- Location
- California
- Vehicle(s)
- Tacoma TRD Sport
High-Brightness LED Bulb: The 7443 LED bulb is approximately 5 times brighter than traditional halogen bulbs, featuring 20 high-quality 3030 LED chips for 360° all-around illumination. Each bulb delivers around 4,000 lumens of light output at 48W. The brightness is precisely measured to ensure clear color rendering, enhancing the driving visual experience. Compatible with the fourth-generation Tacoma.
CANBUS System Compatible: The upgraded 7443 front DRL bulbs come with built-in resistors, compatible with 99% of Tacoma’s CANBUS systems without the need for additional resistors. Multiple tests have verified that they prevent fast blinking issues in turn signals, providing stable lighting performance for your vehicle.
Stable Performance: The new 7443 LED bulbs feature an Intelligent Thermal Control System (ITCS) to maintain stable performance even in high-temperature environments. The bulbs are made with a textured aluminum housing and internal heat sinks to improve heat dissipation and extend lifespan.
These upgraded daytime running lights were very easy to install and made the truck look much better and more noticeable at night time and even during day. They do not hyper flash and work as they’re supposed to
Compatibility: Custom fit for Toyota Tacoma 2024+
Use Code Tacoma4G At Check Out!(20% sitewide)
Order Link: https://lexland.com/xufiw3
