Adding oem inverter?
danbernie19
dan
2025 tacoma trd off road
When I bought my Tacoma a few months ago the dealership had 50+ on the lot but only three 2025s they could sell, all the 2024s were waiting recall repairs. Sadly none of the 2025s had the inverter in the bed which was my most desired feature. Adding the inverter/bed outlet has very little information on the internet, but there is a post where a man identified the inverter wiring in his trucks wire harness without the feature. However, he only posted that one time and didn’t update what he did after that. I have since confirmed that my truck also has the terminated connects for the inverter. I can get the inverter for pretty cheap online and I know Id need the button on the dash and outlet in the bed but I don’t know how to find the other parts of the harnesses that run to those parts. Is this a pipe dream, atleast right now?
Reconsnake
Jake
Sacramento CA
2024 Tacoma Off Road Premium
Keep in mind, there are a couple limitations with the factory inverter. First, it is modified sine wave, meaning that the output of the inverter is more square shaped, and not great for motors or some electronic equipment that doesnt have its own power supply. Second, it is 400 watts while engine is running, and reduces down to 100 watts while driving.
You can solve both disadvantages with a $40 pure sine wave 300 watt Bestek inverter from Amazon. This plugs into 12v outlet, and provides good clean power, that doesnt limit while driving. Although its slightly less output at 300 watts, here is the one I like https://a.co/d/2jczvdM
danbernie19
dan
This is the other option I’m looking at but I’d like to run things from the bed, do just run a cord to the bed or just use whatever you’re plugging in in the cab?
Reconsnake
Jake
Sacramento CA
My taco has a 12v outlet in the center console and one in the bed. Double check if yours does, mine is on the drivers side, under a plastic door cover by the tailgate, along with two USB C outlets and fuse.
BrokeYota
North Idaho
2025 Tacoma SR (Poverty Edition)
How cheap? When I looked it was CRAZY expensive. I installed a Samlex PST-155-12 150 Watt Pure Sine Wave Inverter in the factory location under the console but I haven't finished the install off all pretty with the button and plugs. It just turns on with accessory mode and sits idle until there is a load.
Will721
Quad Cities
You can build a reliable system from the Ol' Harbor of the Freights relatively cheap. RVers have been doing it for years and oddly enough, HF actually listens to their customers so they've been improving rapidly over the years. They have both modified and pure sidewall inverters.
Personally I haven't decided a mounting location for it yet, but once I do I'll be running their 1000watt pure inverter. Then mouting solar on a bed rack with a Lithium battery rack in the spare tires location. I've also been eyeing a solar hood to have onboad trickle charging for the starting battery. Plus I just like how it looks, breaks up the body color.
