Auto Engine Stop/Start feature for which trims?
Brunson
J
Queens
'19 Explorer
The auto engine stop/start (ESS) feature will be on which engines/trims? Will you be able to disable it on all of them?
I know it's on the PreRunner (image below) but I've seen other videos with the Pro and Trailhunter where that button is missing. I assume those were the models without ESS but can't be sure.
2024 Tacoma Auto Engine Stop/Start feature for which trims? auto-stop-start-disable-2024-tacoma-prerunner
2chains
Ruder
Tundra
I noticed that as well! I didn't realize Toyota was doing this...uugh
MJL62
Mark
Kentucky
2024 Toyota Tacoma Limited
It is in my limited trim
ridetime
Oklahoma
I have it but it never engages and I don't ever turn it off with the button. It takes ALOT of foot pressure to engage it. As you press the brake pedal it first has to travel past a certain point to engage the brake hold feature. You have to continue to press past that point to engage stop/start.
The only time mine ever engages is when I intentionally press hard enough to make it happen. The only time I do that is when I roll up to a major intersection that just turned red for my direction of travel. Those lights can take 2-2.5 minutes so I choose to save the gas sometimes.
MJB4450
2025 SR5
The 2WD auto trans have start stop. 4WD and manual trans do not. Simple as that. I bought the disable device. Two minute install.
SnowmanJPS
Halifax, NS
2025 TRD Pro
Anyone have the part number for just the button? I wanna install it to cover the one blank my truck has lol
Vidman
Rick
Mass
Wrong….mine is stop start
soupy1234
Show Low AZ
2024 Tacoma OR Long Bed
That's not the "start stop" that everyone complains about. That's just how Hybrids work. There is no delay to re-start the engine before you can go again because the electric motor is capable of moving the vehicle immediately.
