- Joined
- Dec 12, 2025
- Threads
- 56
- Messages
- 755
- Reaction score
- 622
- Location
- Washington
- Vehicle(s)
- 2025 DCLB SR5
Won this and I've decided not to tune.
Brand New Cobb Accessport for 2024 through 2026 Tacoma. Comes pre loaded with OTS tunes for your Tacoma. Can also have other tuners load custom maps such as OTT, CamTuning, etc.
On sale for $693+ tax from Cobb. Have it listed for $600 locally, $500 for 4G members. Pick up in Bellingham, WA.
Details:
The Accessport is the world's best selling, most flexible, and easiest to use ECU upgrade solution for your Toyota Tacoma i-FORCE. Unlock power hidden within the vehicle by replacing conservative factory settings with more aggressive calibrations. Follow our staged upgrade path with pre-loaded Off The Shelf (OTS) maps or use custom mapping for any modification level. It's the last engine management solution you'll ever need.
This version of the Accessport includes the capability to flash the TCM which is the unit that controls the transmission (AT). It includes various Off The Shelf transmission tunes which adjust shift points, shift firmness, skip shift behavior, and torque limits to fit your preferred driving style.
This Accessport includes a Gateway Bypass Harness. To use it, connect the harness to your vehicle’s OBD-II port, the Gateway connector, and then to the Accessport. The Gateway Bypass Harness enables ECU communication in situations where the Accessport would otherwise be ignored—such as during initial installation, when dumping an unsupported vehicle ROM file, or when recovering from a failed flash. It is not required for map changes or uninstalling the Accessport.
Details:
