Colorado Custom Built Cargo/Kitchen Gear Slide for Long Bed
trailhunger
2024 TH
Built this September '25, tested it on 1 trip to the desert. Works excellent, only selling it because it's a bit much for my ideal setup as I've come to the conclusion I'm more a minimalist at camp. It's capable of holding ~250lbs at termination & 500 lbs stowed according to the slide manufacturer. Heavy duty black powder coated steel slides, WISA Hex Ultralight Marine Ply for the platform, there's even an aluminum 2020 extrusion extension system on this gear slide allowing for a ~125% extension. Comes with a super lightweight COB led strip light (clutch for cooking at night). The alloy L track at the end included for strapping, bikes etc, it's already got threaded inserts seated into the ply. Also included are the slotted alloy L brackets for bolting to the truck bed or track system. Can leave the Dometic faucet mag-plates on there for a little extra.
Weighs 55lbs, can bolt direct to the bed or an L track system like I did, the slides themselves are 60"L stowed. 18" width. Fits a LB Trailhunter with a BedRug, the WISA hex platform can be sized-down to your needs.
Asking $400.
DM if interested. I'm in the Denver/Front range area. I make trips to the CO San Juans in the winter & definitely trips to the Moab area in the spring/summer/fall. Cheers
