GFC Camper Topper & Chase Frame For 2024 Tacoma Now Available
BigDan
BigDan
MD
Just came across this R&T article with more details:
The aluminum camper is built in Montana and custom-fitted to each vehicle it's offered on. The Taco model weighs 266 or 278 lbs, depending on whether you have a long- or short-bed truck, and can support 500-lb dynamic loads on its roof with the optional roof bars. They're also designed so that you can fit solar panels under them. The camper is ringed by a T-track mounting surface, so you can attach awnings, lights, or additional gear. Inside, you get an eight-foot vaulted ceiling with the top deployed and a three-inch thick dual-density memory foam mattress. The bed is preserved, so your fridge, cargo, cooking, and toys can live in weather-tight comfort. And you should be able to stay cool in it, per GFC:
The half inch-thick white honeycomb composite roof reflects solar radiation and provides air gap insulation, which is then complimented by an additional four inches of foam and fabric from the folded tent, plus another inch of composite in the sleeping area floor. Combined with side access panels that can be securely cracked open, intercepting airflow and channeling it through the cargo area, this keeps your truck bed much cooler than possible with traditional topper or camper designs.
2024 Tacoma GFC Camper Topper & Chase Frame For 2024 Tacoma Now Available gfc-2024-tacoma-camper-652ecf710bf88
GOFASTCAMPERS
I found the Camper quite comfortable, though in 25-degree October weather in Yellowstone it definitely got chilly. Still, being off the cold ground is an advantage, and you'll be hard-pressed to find a better (or more ethically) built camper. GFC notes in the release that all workers at its Montana factory are full-time and salaries start at $57,200 with full benefits. That's the highest starting wage of any manufacturer in the state. During a tour of the factory, the owner pointed out that all employees get their own set of Bose noise-cancelling headphones to drown out the GFC-automated CNC machines.
The downside of custom-designed automated processes, high-strength materials, comfortable mattresses, highly rebuildable designs, warrantied products, and living wages is the the Platform Camper's cost. The Tacoma model will start at $7700 before things like the optional crossbars. And don't worry that the truck isn't out yet. GFC's earliest delivery for any tent ordered today is January 4, 2024. So if you want one next year, you might want to order soon.
2024 Tacoma GFC Camper Topper & Chase Frame For 2024 Tacoma Now Available gfc-space-frame-2-652ecfddb9efa
StreeTaco
TN
2024 Tacoma TrailHunter
Would love if the platform camper had a better fit near the cab. This, although understanding it needs to be somewhat universal, seems rushed and not as R&D’d as I’d like to see for this new truck. If they would create a more attractive fit and also leave a way to still utilize the bed lighting and camera system, I’d be more inclined to purchase.
