Heritage Bronze is not 4T0 color code (touch up paint) ... so what is it?
4g hybrid
Title says it all. Trying to get to the bottom the of the exact color used for the heritage bronze on badges, wheels, and center caps.
Ordered 4T0 touch up. Painted it onto white cardboard. Comparison photo included.
Now... Who can figure out the real color code?
2024 Tacoma Heritage Bronze is not 4T0 color code (touch up paint) ... so what is it? PXL_20250302_192932726
tgrneal
Aaron
Huntsville, AL
Tacoma Trailhunter
Also interested in this
OffRoadUSA.com
offroadusa.com
'22 Tacoma
You're right, the Heritage Bronze color isn't 4T0. The correct color code you're looking for is 6X1, which is called Bronze Oxide. That's the one that Toyota uses for things like the bronze wheels, emblems, and accents on the newer models.
If you're trying to grab some touch up paint, look for the part number 00258-006X1-21. That’ll match the Heritage Bronze accents way better than 4T0.
Hope that helps!
BoboForShort
Tyler
Florida
2024 Tacoma Trailhunter
Hope that helps!
Pretty sure the bronze oxide body color is not the same as the bronze accents on the Trailhunter. Are you suggesting that they are the same or are they both called bronze oxide?
4g hybrid
Hope that helps!
That's the body color of Bronze Oxide, not of the accent color known as Heritage Bronze Matte.
Thanks though - the hunt continues!
heavylunch
Wisconsin
2025 Tacoma Bronze Oxide Trailhunter
Was this ever solved? Is it closer to sinister bronze from tufskinz?
tgrneal
Aaron
Huntsville, AL
Tacoma Trailhunter
The color is Bronze oxide. I've ordered touch up paint and it matches.
4g hybrid
You are misunderstanding this thread.
We aren't talking about the body color. We are taking about the heritage bronze accent color used in the trailhunter grille lettering, the heritage wheel, and the heritage wheel center caps...
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
I did a little bit of digging, and came up with the potential color match 4T3 for the bronzed wheels and trim of our Trailhunters. Note this item is non-returnable.
Amazon USA
https://a.co/d/56buc8C
Aftermarket paint match company
Toyota Bronze Pearl Metallic (4T3) Exact-Match Brush Bottle – DIY Repair for Medium Chips and Scratches (2oz)
https://shop.paintscratch.com/colors/toyota/bronze-pearl-metallic-4t3/bottle
2024 Tacoma Heritage Bronze is not 4T0 color code (touch up paint) ... so what is it? IMG_9182
4g hybrid
Amazon USA
I wonder if someone will order a touch up bottle or pen and test. That's what I did for the 4T0 which confirmed it was not a match.
lauren01
Lauren
Ventura, CA USA
I’m going to order the bottle from Amazon since it appears to be a Toyota genuine item.
Stayyyy tooooneddddd
lauren01
Lauren
Ventura, CA USA
It should arrive by the middle of next week….from the right coast to the left coast.
2024 Tacoma Heritage Bronze is not 4T0 color code (touch up paint) ... so what is it? IMG_9184
