HitchMount LED Pod Reverse Kit | Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
2021 Toyota Tacoma
2024 Tacoma HitchMount LED Pod Reverse Kit | Diode Dynamics kQHrEwn
Add significantly more light output when backing up at night with our Stage Series HitchMount Reverse Light Kit!
2024 Tacoma HitchMount LED Pod Reverse Kit | Diode Dynamics 2tK1RHX
This kit allows you to mount one SSC1 or C1R LED pod in your 2-inch trailer hitch receiver, adding a high-power reverse light, additional running light, and an optional 4th brake light with the C1R option. With the included wiring harness, this kit connects to the Toyota Tacoma's factory trailer hitch wiring for simple, everyday operation.
2024 Tacoma HitchMount LED Pod Reverse Kit | Diode Dynamics JH3bSqv
Brighter Backup. Factory reverse bulbs just don't provide enough light output to back up at night confidently. By pairing our patented TIR optics with high-powered LEDs, the SSC1 and C1R included in this kit provide an additional reverse light that's several times brighter than stock bulbs alone. Plus, they automatically come on when the vehicle is put in reverse!
2024 Tacoma HitchMount LED Pod Reverse Kit | Diode Dynamics Uw2VXj0
Additional Running Light. The Stage Series LED pods included with this kit feature a distinctive red backlight that can be used as an additional running light while driving! The backlight fully illuminates the TIR optic, providing a more unique and modern look than the small indicator LEDs found in other products.
2024 Tacoma HitchMount LED Pod Reverse Kit | Diode Dynamics g6ecyP6
SafetyStrobe 4th Brake Light. The C1R option features a high-power red function to serve as a powerful 4th brake light, along with the low-power running light. The high-power red functionality activates anytime you apply your brakes, adding a 4th brake light to your Tacoma. The C1R also features optional brake light strobing, which can be activated in 15-second intervals. By default, the C1R will flash three times when the brake lights are initially applied, for greater visibility. The SafetyStrobe feature can be easily disabled if desired.
2024 Tacoma HitchMount LED Pod Reverse Kit | Diode Dynamics 80vc0pr
Everyday Operation. This kit is completely plug-and-play with all 7-pin trailer connectors. The included harness plugs right into your factory trailer hitch wiring for easy installation and operation. The kit operates as an additional red running light with your tail lights, and then automatically switches to a high-power backup light when your vehicle is in reverse. The high-power 4th brake light feature included with the C1R will activate anytime you apply your brakes. If you would like to have override functionality to manually turn on the reverse light anytime, you will need to purchase the universal backup harness.
Simple Installation. The patent-pending snap-fit design allows you to install this mount in minutes, without any drilling or need for a hitch pin. Simply insert the HitchMount into your trailer hitch receiver and the snap-fit side mounts will snap into place. Installation couldn't be easier and takes less than five minutes! This kit is ideal for anyone who uses their trailer hitch often since removal can be done in minutes as well! Simply unplug the harness, press the snap-fit pins and remove the mount. When you're not using your hitch for towing, you can quickly reinstall the HitchMount and plug it back in.
NOTE: If you would like to use a locking trailer pin to install this kit instead of the snap-fit pins, you can do so with a quick modification. This product is not intended to replace original factory tail lamps. Please ensure your trailer hitch has an open back before ordering.
Focused. Traditional optics like reflectors or simple lenses lose light internally and to glare, so not all of the light shines on target. Instead, the custom-engineered TIR optic in our Stage Series pods collects all of the light from the LED, and directs it only where you need it, drastically reducing glare and improving total efficiency. Click here to learn more: Total Internal Reflection (TIR) Optics | Stage Series Video.
From there, while other options on the market lose as much as 10% of the light output shining through an outer lens, the custom-molded TIR optic in the Stage Series LED pods serves as both the optic and main lens for greater efficiency and light output (patent pending). Thanks to this innovative feature, when coupled with high-intensity LED chips, the total intensity of our pods is much greater than other LED pods using basic optics or reflectors with a standard outer lens.
Functional Output. All Stage Series beam patterns were designed with optical simulation modeling, to shape the output in a highly-functional beam pattern.
Flood pattern was designed to provide uniform, even illumination with a full 50x50 degree spread of light on the SSC1 LED pod. Unlike generic "flood" lights that are simply a heavily diffused spotlight, our flood pattern uses pillow optics on the outer lens surface, to provide a true optically designed spread, for even illumination throughout.
2024 Tacoma HitchMount LED Pod Reverse Kit | Diode Dynamics 4qFMdSa
In the Box:
  • One (1) SSC1 Sport or C1R HitchMount LED Pod
  • One (1) 7-Pin trailer single output harness
  • Two (2) Zip ties
  • Installation guide
Experience. After over a decade in business, Diode Dynamics is one of the most trusted names in automotive LED lighting. We directly assemble and engineer an increasing number of products in the United States, allowing for higher quality and performance, with the newest and brightest LED technology. No matter what you're driving, we pride ourselves in offering only the best possible LED solutions. Please contact us if you'd like to discuss your lighting project
Questions/Concerns:
Hours:
Monday-Friday 10 a.m. - 5 p.m.
Email: [email protected]
Phone: 314-205-3033
Forum Member Benefit: All forum members are eligible for a free US shipping code. Please send us a direct message for the exclusive code and save on any new or future order.
John C.
Diode Dynamics
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
2021 Toyota Tacoma
Has anyone installed this yet? I like the idea of the C1R but don't want to splice wires.
There is no wire splicing for the 2024 Toyota Tacoma C1R HitchMount LED Pod Kit.
It is 100% plug-and-play and ready to install in under 5 minutes.
Here is a video example of the installation process:
rptls
North Carolina
24 TRD OR Hybrid
Anyone run this using the oem switches? I’m thinking of ordering the hitch pod as well as the other reverse pod kit and wiring 1 to the switches.
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
2021 Toyota Tacoma
The harness is designed to operate off factory vehicle signals. You could have manual control, but would have to build a custom harness as one is not offered by our team.
Mini2nut
This is exactly the 4th brake light design I have been searching for. I tried hooking up a cheap eBay 4th brake light but I removed it because of the unsightly electrical wiring.
I like how the light serves as a running light, 4the brake light and bright reverse light.
The way DD hid the wiring harness is very well done. Great job DD.
Order submitted!
BennettH
Bennett
‘25 Tacoma Bronze Oxide
Literally a 5 minute install! So easy you could do it in the dark, blindfolded :cool: .
Nice Product
trailhunger
2024 TH
I installed the hitch pod last November '24 and use it on its own switch off my AUX 1 pigtail. Mainly for camping. I have a 3rd brake light on my GFC. All things being equal it's the least used accessory I've installed on the truck, but handy when it's pitch black. I actually ordered the reverse harness kit from them but ended up splicing that unit for my GFC's 3rd brake light, so nothing wasted and it worked out great
2024 Tacoma HitchMount LED Pod Reverse Kit | Diode Dynamics 1764387232382-md
Mitch33
‘24 Tacoma OR
2024 Tacoma HitchMount LED Pod Reverse Kit | Diode Dynamics {filename}
Do you remember how you went about using the DD harness to wire in your GFC 3rd brake light? I want to do something similar with a wedge camper I'm having built and this harness seems to be the simplest solution I've found so far. Also do you get purely brake light from the DD harness to the GFC or does it flash with turn signals? Thanks!
trailhunger
2024 TH
Nope my 3rd brake light does NOT FLASH w/turn signals. Honestly I dialed up some chatGPT and send it pics and it told me which wires to tap into. Couple that with 6 months of internship soldering LED lights for a furniture & design lighting company I worked for 15 years ago…in one ear out the other bro. I can send a pic of it tomorrow but yeah interface with AI is my recommendation
Tacolorado
2024 Tacomo
I like this a lot, but I would fear somebody would help themselves too pretty easily. does it lock in place?
