NEW! Scene Light Kits | Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
2021 Toyota Tacoma
Scene Light Kits are here. Built around our Dual-Color Rock Lights, these kits are designed to turn your rack into a true lighting solution. You get strong, usable white output when you need it, plus a secondary color for low-glare use, all in a complete package with mounts, wiring, and hardware included. No piecing parts together, just a clean, purpose-built setup ready to install.
Get two lighting modes in one setup. White provides strong output for working, loading, and setting up camp. Amber or red gives you a lower-glare option that helps preserve night vision and keeps your setup comfortable after dark.
Built for real scene lighting, not just brightness. The wide beam pattern fills in the space around your vehicle with usable light. White gives you full output when you need to see everything clearly, while amber or red lets you maintain visibility without overpowering your surroundings.
The bracket design is what makes these work as true scene lights. It directs light outward and down where you actually need it, while keeping the lights low-profile. The compact design stays out of the way of other accessories, including rooftop tents and gear mounted to your rack.
These kits are designed to integrate across a wide range of rack systems. They mount cleanly to popular platforms like Prinsu, RCI, Sherpa, and Westcott, while still offering flexibility for other builds and custom setups.
Questions/Concerns:
Hours:
Monday-Friday 10 a.m. - 5 p.m.
Email: [email protected]
Phone: 314-205-3033
Forum Member Benefit: All forum members are eligible for a free US shipping code for orders. Please send us a direct message for the exclusive code and save on any new or future order.
John C.
Diode Dynamics
TrailAdventurer
JT
Canton, MI
Good timing. Just put an ARB Canopy w/load bars on Riddick.
How are in the on/off and color selection controlled? Are you requiring two separate switched circuits? Or is color a manual toggle?
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
2021 Toyota Tacoma
Our kits include a simple 3-way toggle to choose between off, white output, or red output. Of course, you can wire the kit however you see fit to factory aux switches or a switch panel, if you choose!
