NOW AVAILABLE! Form Lighting Tail Lights 🚨
Panda Motorworks
O'Fallon MO
2025 Tacoma SR5
Looking to upgrade the rear end of your Tacoma? This is one of those mods that instantly changes the entire look of the truck.
Introducing the Sequential LED Tail Lights from Form Lighting, built specifically for the 4th Gen Tacoma and heavily inspired by the bold tri-bar design from the Tundra. If you’ve been waiting for something that actually looks OEM+ (not cheap aftermarket), this is it.
What Makes These Stand Out
Modern, OEM+ Design
These use a tri-bar layout where all three bars light up for running lights, brake, and turn signals. The optics are factory style, so you get smooth, evenly diffused light instead of that harsh, spotty LED look.
Sequential Turn Signals + Startup Animation
You get a clean sweeping turn signal across all three bars, plus a startup sequence every time the parking lights come on. Both features can be turned off during install if you want to keep things simple.
Smoked or Red Options
Smoked = true tinted optics (not spray-painted junk)
Red = classic, bold OEM-style look
Either way, both illuminate bright red and stay fully road legal.
Built Right (Not Just for Looks)
  • OEM-grade polycarbonate lens with UV coating
  • Automotive-grade LEDs and optics
  • Direct-fit connectors (no splicing, no headaches)
  • SAE & DOT compliant
  • Integrated reflector + proper light output
These aren’t the cheapest option out there, and that’s kind of the point. The fit, finish, and light quality are on another level compared to most aftermarket housings.
Easy Install
Completely plug-and-play.
No hyperflash, no flickering, no dash errors.
You’re looking at under 10 minutes to install both sides.
Warranty & Support
Backed by a 2 year warranty with US-based support. If anything ever comes up, replacements ship quick and the process is straightforward.
2024-2026 Tacoma LED Tail Lights
Panda Motorworks
Panda Motorworks
O'Fallon MO
2025 Tacoma SR5
For the rest of May, when you purchase a set of Form Tail Lights, we will include a FREE Matte Screen Protector with your order! You will be promoted to add it to your cart, just select the 8" or 14" screen option.
Wife bought my 24 TRD
Anthony
Aberdeen Wa
What is the quality comparison to these lights.
Also does it make the Truck go faster and jump farther? Just wondering why anyone would replace these unless you had been in a accident and had to replace them 🤔
