Now Available: Mabett 4-Piece Rear Bumper Crossmember End Caps + Front Grille Side Trim
Mabett
LA
www.facebook.com
2026 Tacoma TRD Sport
Hi everyone, Jeremy from Mabett here. :clap:
Our new 4-piece Rear Bumper Crossmember End Cap Set is now officially available, giving you coverage for all four exposed crossmember ends. We’re launching it alongside another new exterior upgrade for the 2024–2026 Tacoma: Front Grille Side Trim.
Fitment
Both products are designed for the 2024–2026 Toyota Tacoma.
For the Front Grille Side Trim, please compare your front bumper shape with our fitment photos before ordering.
Tacoma4G Launch Offer💥💥
40% OFF, now $11.99
Use code Q0ITINKO at checkout: https://www.amazon.com/dp/B0HC5LXNFP
30% OFF, now $13.99
Use code 8M5068HV at checkout: https://www.amazon.com/dp/B0HDJ1J9FX
Complete 4-Piece Coverage
The set includes 2 side caps and 2 rear caps, covering all four exposed ends for a cleaner, more finished look.
Reinforced Snap-In Fit
Each cap uses built-in locking tabs and reinforced edges to grip the factory opening and stay securely in place while driving.
Installation is straightforward: align each cap with the correct opening and press it into place. No tools or drilling required.
Helps Keep Debris Out, Built for Exterior Use
The caps help keep mud, water, snow, dust, and road debris from collecting inside the exposed crossmember openings, while also helping discourage mice and other small animals from nesting there.
Since this area is constantly exposed to road spray, dirt, heat, and changing weather, we chose TPE instead of conventional SBR rubber for better resistance to wear and long-term outdoor use.
This 2-piece trim set extends the factory black trim downward on both sides of the front end, adding a sharper, more finished look without replacing or modifying the original grille.
The design follows the factory contours and combines raised 3D ribs, a matte black finish, and a tapered tip for a subtle OEM-style upgrade.
Full-surface pre-applied adhesive provides broad contact with the bumper surface. Just clean the area, peel the backing, align the trim, and press it into place. No drilling or wiring required.
Which One Would You Add First?
Between the rear bumper end caps and the Front Grille Side Trim, which one would you add to your Tacoma first?
Get an extra 10% OFF when you join the Mabett 4th Gen Tacoma Garage. Members there also get early product updates, member-only offers, and selected opportunities to try new arrivals.
Mabett
Mabett
LA
www.facebook.com
This Tacoma4g-exclusive discount is available until October 11th!
