Oil filter wrench
The Dude
Richard
Calgary, Canada
I’m looking for a new filter wrench for the thimble of a filter on our trucks. My band-style is too big for this little guy, and I had a devil of a time getting the old filter off by hand. One I’m looking at is this style, but I need to know the diameter of the filter, so I get the correct one. This one is 64.3mm, which sounds right, but I’m unsure. Does anyone know? Thanks.
2024 Tacoma Oil filter wrench IMG_0636
saerandy
Randy
Virginia
2024 SR5
While I do not know if this one fits good enough, I've struggled with filter wrenches on-and-off. It it's on tight I've found the filter casing warps and then its even harder to get them off. A couple of years ago I bought the Workpro Oil Filter Wrench Set off Amazon ( https://amzn.to/4lPwE4F ) and am super happy with it. The larger wrench is what works on our filters, and you can get excellent leverage using it.
TX-MD
marvin
AR
Tacoma, 4Runner
I have this for our ES and it worked for my 4th gen but the filter fits the “inner ring” since it’s such a tiny filter lol
https://a.co/d/4jVcagX
Bravada
S.E. Texas
The Dude
The Dude
Richard
Calgary, Canada
I’m liking all the suggestions everyone. I figured being so small, I’d need an exact fit, thankfully, looks like I was wrong. :thumbsup:
Virtual beers for everyone!!
holden
Holden
Scottsdale
'24 Toyota Tacoma TRD Pro
@holden That oil drain valve looks good - have you used it already and does it work as advertised?
holden
Holden
Scottsdale
Works perfectly. The valve screws over top of the oil drain and has a protective metal cap. When changing oil, you remove the cap and screw in the drain tube. The oil will only begin to drain once the drain tube is fully screwed in, and you can even control the rate at which the oil drains (if you overfill and only need a few ounces out) by tightening/loosening the drain tube over the valve. Great little contraption. The video in the amazon ad demonstrates it well.
I didn't buy the optional bag, mostly because I had an oil pan, but I'm sure it would work even better as a set.
The hardest part of my oil changes is realigning the holes in the TRD skidplate while I'm laying underneath it :crackup:. Thing is heavy.
SuperDave19
Virginia
2025 Tacoma TRD Off-Road
My solution is to buy the k&n oil filter with the nut welded on the end. Socket and ratchet is all I need for my oil changes!
Strap wrench works perfectly fine for me
PRO_Taco
Garett
Ontario Canada
2025 Tacoma TRD Pro 2017 Tacoma TRD Pro (sold)
TOY468 wrench from snap on works perfect
jackvz
Jack
richmond
2025 Tacoma Trd Pro
Is there any way that filter can be changed out without removing the skidplate? If so, I might use a Fumoto valve and cut a hole in the skidplate
Amorak
Oklahoma
2025 Tacoma TRD Pro, undergound w/ red interior
Yes, pretty much "check mark" on all of this on the ValvoMax (y)
