Toyota Paint Thinness
JHunter
Everett,Pa
2017 Ford Explorer
Hello again everyone,
My other question concerns how amazingly thin Toyota paint is.
Living in Western Pa has both pros and cons and one of the cons is that the front end of your car can get chipped easily.
Based upon prior experience, Toyota finishes are extremely thin and chip with great ease.
Does anyone know if Toyota has improved upon the durability of their paint finishes?
Thank you,
JHunter
JLD94
JD
Tx
Thank you,
JHunter
So you currently own a toyota? I don't, but was unaware to paint issues
Nuke
Jim
Rexburg, ID
2021 Highlander Platinum
There is a YouTube channel wherein the reviewer evaluates vehicles, and one of his procedures is to measure paint thickness. Toyota is not lacking in this regard. As far as paint becoming chipped, another issue I believe. As of late I have opted for the frontal paint protection films, and they seem to do a good job.
JHunter
Everett,Pa
2017 Ford Explorer
I owned two Camrys, one FJ Cruiser, one Tacoma TRD Sport and one Corolla. The Camrys and FJ Cruiser had NO paint issues, when it comes to chipping. The Corolla and Tacoma were entirely different issues. The Corolla was made in Japan and the Tacoma was made in San Antonio, Texas. I understand why auto manufactures use the paint millage that they use but, when compairing the last 5 years of both Toyota and Ford ownership, Toyota looses the paint durability test.
JHunter
Everett,Pa
2017 Ford Explorer
Yes, I will probably coat the entire front clip, including the bumper. The only issue is that prolonged usage of these films can damage the paint as it has to cure for at least 60 days before the film should be applied.
Nuke
Jim
Rexburg, ID
Wow, was not aware of that! Darned if you do the film, darned if you don't. I always have ours factory applied, not aftermarket, and that would certainly be less than 60 days for the paint to cure.
JHunter
Everett,Pa
2017 Ford Explorer
Yeah, it is a bit of a conundrum. My approach for my next Tacoma purchase will be to purchase it in the late Spring and ride out the 2 month paint curing process. Then have the film applied to the entire front clip.
Tom59
Thomas
New England
02 Tundra ISE, 2012 CT200h, 2015 NX 200t
I've had film on my last few vehicles Lexus though and that film saved our paint job from the salt and sand they put down here. No discoloration if they use the right film. My CT200h was done 11 yrs ago... looks like new the only blemishes are in the film which comes off.
MJB4450
2025 SR5
I regret not getting the front end covered the day I bought it. But I didn't think it would be that necessary until I noticed I had a couple chips with just 20 miles on it at time of sale and a couple more shortly after. I also was astounded when I tapped, not hit but mildly tapped the corner of the door on something smooth and it chipped. That's when I noticed how insanely thin the paint was. So thin I couldn't even feel it with my fingernail. They must air brush the paint on with one light coat. That's why they're having white buy backs and silver by backs for bad paint. Mine is the Supersonic Red. But while I was at the dealership I noticed every blue one I looked at had paint defects on the right bedside above the wheel. So it's all the colors I thought buying the extra cost color would get me some consideration at the factory, but nope. There's been complaints about the paint from day one and nothing has changed. So obviously they don't give a crap. As much as I like the drivetrain on this truck, the paint issue will be a heavy factor on if I buy another.
The paint on my bed sides chips without any effort. I PPF’d the hood, bumper, mirrors, and part of the rear fender flare area and I’m generally fine — but it is a black mark in my mind for toyota quality. They consistently skimp on paint. And paint is important!!!
RutsyBucket
Hunter
Carlsbad, CA
2025 Terra Off Road
knock on wood... my paint has been perfect. Im guessing they give terra a thick layer or something because I haven't seen any of the issues everyone talks about.
soupy1234
Show Low AZ
2024 Tacoma OR Long Bed
Mine got a little thinner yesterday.
2024 Tacoma Toyota Paint Thinness 1000010119
Where did I put that can of gray primer...
soupy1234
Show Low AZ
Fuck it. Send it and never look back.
Last scratch included a tail light. I didn''t fix that scratch either.
Edit: I did replace the tail light. It was expensive😭
