2024 Tacoma REAR Door Card Removal
HawkeyeTaco24
Southern Cali
Hello! First time posting anything in any forum, but I had zero success trying to find out how to do this elsewhere until I did it myself. 90% of the removal is push clips similar to the front door panel which are easy to pry off. The door handle plastic cover is just the same as well. Only tricky part is the window control switch which requires a thin pry tool and a secondary to shimmy in and pry upwards. I started from a bit off of the middle like in the photo and pry upwards/ inwards. The rest is easy once the first clip is off (just keep repeating the process until the furthest left side). Hope this helps anyone for any speaker upgrade or sound deadening install :):beer:
2024 Tacoma 2024 Tacoma REAR Door Card Removal IMG_3179
2024 Tacoma 2024 Tacoma REAR Door Card Removal IMG_3180
2024 Tacoma 2024 Tacoma REAR Door Card Removal IMG_3181
2024 Tacoma 2024 Tacoma REAR Door Card Removal IMG_3182
2024 Tacoma 2024 Tacoma REAR Door Card Removal IMG_3183
2024 Tacoma 2024 Tacoma REAR Door Card Removal IMG_3184
Wife bought my 24 TRD
Anthony
Aberdeen Wa
Thank you for taking the time to show great photos and explain exactly what you have done. ?
Sancheesy
Shawn
Ontario
This is great thank you. I'm thinking of upgrading the speakers soon.
HawkeyeTaco24
Southern Cali
These trucks seem to be lacking in the sound department, even with the JBL system from what I’m aware of. Luckily the process is pretty straightforward ?
AltarBoy
New york
21trd off-road
Since you removed the panel did you notice how the accent panel attaches? On the fronts they slide out but I can't get the rear door accent pieces out the same way.
HawkeyeTaco24
Southern Cali
The back panel’s accent pieces don’t slide out. The way to remove the rear the back door panel is removing 3 screws shown in pictures and everything else you just pry off, staring with the trim next to the window.
