- Joined
- May 21, 2024
- Threads
- 73
- Messages
- 205
- Reaction score
- 60
- Location
- Ontario. California
- Website
- www.lasfit.com
- Vehicle(s)
- Toyota Tacoma 2024
After discovering the brightness difference between halogen bulbs and T3 LED lights, you might be intrigued by the little change brings huge difference. But is replacing the bulb a hassle?
Actually, replacing some car lights can be a time-consuming task. Depending on the location of the light, some cars even require removing the bumper to access them. Plus, without built-in decoders, you often need extra resistors to prevent hyper-flash and error codes, which means more wiring and installing space for those resistors.
But for 2024 Toyota Tacoma owners, none of this is a problem! You can do it yourself with a quick and easy 5-minute installation, thanks to the T3-7443 LED bulb’s built-in canbus ready. No extra decoders needed—just plug and play! You’ll be up and running with these LED lights in no time.
4-Steps Installation
Step 1: Open the hood, push the 4 push clips, and remove the air cleaner inlet. This step is only needed for the passenger-side turn signal. For the driver's side, it's just 3 steps!
Step 2: Turn counterclockwise and twist out the halogen light.
Step 3: Pull out the halogen bulb, and insert the LED bulb into the socket.
Step 4: Put the LED bulb back into the assembly.
You can learn more about installing the T3-7443 LED bulb on the 2024 Toyota Tacoma in the video below:
Have you installed aftermarket LED bulbs on other vehicles or your 2024 Toyota Tacoma before? Or are you worried that extra resistors might make the installation tough? Feel free to leave a comment below and share your installation experiences!
