2024 Tacoma Alignment - Rear Axle Toe and Thrust
loosewires_
San Diego CA
I recently took my truck to get an alignment after slapping some new tires on. The tech mentioned that I have a negative thrust angle on my rear axle. I haven't done anything to the suspension. I take it off-road, but definitely don't abuse it. This is also my first alignment I've done since I bought the truck new.
I could be totally wrong, but it looks like in the before measurements, that the rear thrust angle was being compensated for by adjusting the front toe. My steering wheel used to be dead-on straight. Now after the alignment my steering wheel is always cocked to the right.
The tech told me I can bring it back and he can revert to the old front toe settings. Is that the way forward or should I attempt to figure out what's causing the rear toe/thrust angle to be off? Will reverting to the old toe settings cause any damage or uneven tire wear?
Any other advice would be much appreciated. Just want to make sure my truck lasts as long as possible.
