- First Name
- Jake
- Joined
- Feb 8, 2024
- Threads
- 12
- Messages
- 123
- Reaction score
- 86
- Location
- Fort Worth, Texas
- Vehicle(s)
- 4th Gen Tacoma
Welcome
Cali Raised LED
www.CaliRaisedled.com
Phone: 888-385-5036 l Email: [email protected] l Instagram: @cali_raised_led
https://caliraisedled.com/products/bed-channel-supports-and-stiffeners-for-2024-toyota-tacoma
If you're running a rack, rooftop tent, or hauling heavy gear in your 2024 Tacoma, bed stiffeners are a must-have. These bed channel supports reinforce the rear bed corners—an area known to flex or even crack over time under load or off-road stress.
We designed these for the 4th Gen Tacoma frame and composite bed, using strong, gusseted steel to brace the weak points without interfering with your cargo or tie-downs.
Key Features:
- Fits 2024+ Toyota Tacoma (4th Gen)
- Reinforces rear bed channels – Reduces flex and prevents long-term damage
- Bolt-on design – Installs using factory bolt locations and included hardware
- Steel construction – Black powder-coated for weather resistance
- Compatible with bed racks, RTTs, and recovery gear setups
- Made in the USA – Trail-tested and welded here, not overseas
Whether you're wheeling hard or daily driving with a loaded bed, these supports add long-term durability and prevent costly repairs down the road.
Install Notes:
Installs in under an hour with hand tools. Mounts behind the factory D-rings—no cutting, drilling, or special tools needed.
What do bed stiffeners do?
They brace the rear bed walls where Toyota’s composite beds are most vulnerable. This helps prevent cracking or deformation from overloading, rough terrain, or rack-mounted gear.
Do these work with factory bed tie-downs?
Yes, you retain full use of your OEM bed cleats and tie-downs. These mount behind the tie-downs and use the same bolt pattern.
Product Page:
Get full details or grab a set here:
2024 Tacoma Bed Stiffeners
Let us know if you’re running a rack or tent—we’d love to see how you’ve built it out.
Install video
