A More Visible Front Tow Point for the 4th-Gen Tacoma — Mabett Tow Hooks Now Available
Mabett
LA
www.facebook.com
2026 Tacoma TRD Sport
Hi everyone, Jeremy from Mabett here.
Our new Mabett Front Tow Hooks are now available for the 4th-Gen Tacoma, adding a clear, easy-to-spot front connection point for trail and recovery setups while giving the front end a stronger off-road look.
Fitment Note
Designed for 2024–2026 Toyota Tacoma Double Cab.
Includes both left and right front tow hooks.
Machined Aluminum + Anodized Red Finish
Made from high-strength aluminum alloy with a lightweight, precision-machined design. The anodized red finish helps the tow points stand out while adding a clean off-road accent and extra surface protection against corrosion, chipping, and UV exposure. :like:
Ready for Recovery Gear
The hooks provide accessible front tow points for compatible recovery straps and shackles, making the connection setup more straightforward when you need it on the trail.
No-Drill Bolt-On Installation
The hooks mount directly to the factory front tow-point locations, so there’s no need to drill, cut, or permanently modify the truck.
  • Uses factory mounting bolts
  • No drilling or cutting
  • Basic hand tools only
  • Installation takes about 10 minutes
Tacoma4G Launch Offer💥
Discount: Save 25% — get the 2-piece set for just $29.99 with the promo code below.
Promo Code: 74MON84U
Enter the promo code at checkout to apply the discount.
Product Link:
https://www.amazon.com/dp/B0H3FFHBC5
Questions or Feedback?
If you have any questions about fitment, installation, or recovery use, feel free to leave them below. We’d also appreciate hearing your feedback once you’ve had a chance to use it.
Join the Mabett 4th Gen Tacoma Garage to claim an additional 10% OFF on top of the launch discount. We’ll also share future product updates, exclusive member perks, and selected product testing opportunities in the group.
Mabett
Mabett
LA
www.facebook.com
You know the drill — drop your thoughts in the comments below!
Sner
Guessing there is no weight rating for them. Assuming if you needed tow hooks for recovery, you’d be best to just leave the OE ones installed and if you want red, just grab a can of red tremclad and paint them red.
