Protect Your Tacoma’s Tailgate Step Surface | xipoqix
xipoqix_official
Jackie
China
The step surface can easily get scratched and look worn. Moreover, on rainy days, the step surface gets wet, making it easy to slip when stepping on it.
The Rear Bumper Step Pad is compatible with 2024 2025 2026 Toyota Tacoma.
It can protect the step surface when loading and unloading luggage or carrying items. It can also cover the original scratches and wear marks on the step surface, making it look brand new. The anti-slip texture on the surface can effectively prevent slipping and injury when entering or exiting the trunk, providing an additional layer of safety.
Made of high-quality TPE material, it is flexible, scratch-resistant and wear-resistant. It has no bad smell. It can still maintain structural stability even under extreme temperatures. You can use it with confidence. It is easy to clean, just wipe it with a damp cloth or rinse it with water. Easy to install and no drilling is required. Just peel off the adhesive tape on the back of the product and stick it.
Get yours here: https://www.amazon.com/dp/B0HC3RCVMZ
