Easily Access Your Cargo Bed with Our Rear Bed Step | xipoqix
xipoqix_official
Jackie
China
For owners of the Toyota Tacoma, accessing the cargo bed can be challenging due to the vehicle's high ground clearance.
This Rear Bed Step makes things a lot easier. It gives you a solid place to stand, so you can grab items directly from the side without having to fumble with the tailgate every time. When you do need to climb into the bed, it serves as a helpful step to get you up there more comfortably.
Built from high-strength carbon steel, this step is designed for long-term use, standing up to the elements. The surface features a hollowed-out design that lets rain drain right through, so you don't have to worry about water pooling up and making it slippery.
The step is specifically designed for the passenger side of 2024–2026 Toyota Tacoma. It utilizes existing mounting points on the truck's frame for a straightforward, screw-on installation.
Get yours here: https://www.amazon.com/dp/B0H1C55TH6
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
Would like one for the left side (driver side). Many of our trucks have the trail exhaust so it won’t interfere.
lauren01
Lauren
Ventura, CA USA
Looks like we can’t use this with trucks that have the factory ARB recovery point…please advise. Maybe it would work with the SXTH bed step relocation bracket. I’d be willing to test that for you.
xipoqix_official
xipoqix_official
Jackie
China
Could you snap a photo of your recovery point like the one below? It’ll help us see how it’s mounted and figure out a solution. Thank you!
4g hybrid
I keep passively hunting a step today looks exactly OEM, tucks up, but on the left (drivers) side. Ideally with the recovery hook maintained.
(I only have the ARB on the left, but use it for easy four legged long line attachment more than anything)
