marie_arb
Marie
Seattle, WA
Toyota
If you've been holding off on a bumper and winch for your Tacoma, now's the time to head over to our website and get your new setup.
Buy an ARB Front Bumper with an ARB Winch between September 1 and 30, and we'll include the ARB Weekender Recovery Kit and the ARB Winch Extension Strap at no cost.
Get your recovery gear squared away before snow season hits without paying extra for it.
Why Upgrade Your Front Bumper?
Your factory bumper is just a plastic fascia, not built for trail obstacles. If you're running technical trails, a bumper and winch aren't just a game changer for any recovery situation; they protect your front end far better than anything stock.
Ready to upgrade your bumper? We offer two front bumper options for the 2024+ Tacoma. The Summit MKII (It’s finally here!) is the heavier-duty build, with integrated LED lighting and extensive underbody protection. The Zenith sits lower for a better approach angle and has 8-ton recovery points built in. Both take winches up to 10,000 lb and keep your factory safety systems intact. Not sure which is better for your build? Ask below.
Pair either bumper with an ARB Winch, and don’t forget to add the Hawse Fairlead Spacer Kit; it's required for installation. Then it’s almost time to hit the trails; you’ll still need to come prepared with a stocked recovery kit.
The Rest of Your Recovery Kit
A bumper and winch give you the anchor points; now it's time to stock the rest of your recovery kit, aka the tools that will help you and anyone else get unstuck. What you actually need will vary depending on the trails you run, but at a minimum, we'd suggest keeping a snatch strap, a pair of shackles, and a winch extension strap on hand alongside your winch.
The snatch strap does most of the work. It's built to stretch about 20% under load, so it stores energy as the recovering vehicle pulls away and releases it gradually instead of shocking the recovery points on either end. The shackles are what connect that strap to your truck, so buy them in pairs and make sure the Working Load Limit matches your strap. The extension strap is just that, an extension to your winch line in case your anchor point isn’t close enough.
We know there are so many other important pieces of recovery gear. What else would you include in a recovery kit? Bonus points if you show us some photos of your ARB recovery gear in action!
Get your Recovery Kit for FREE!
Don't have anything to get you unstuck yet? We've got the deal of the summer to help fix that issue. Buy any of our front bumpers with an ARB Winch between September 1 and 30, and the Weekender Kit plus the ARB Winch Extension Strap are included at no charge.
Questions? As always, drop them below. Just want to talk about how much you love our products; that’s also very welcome! And don’t forget to add some photos. We always love to see your ARB gear in use.
Browse the Summit MKII, the Zenith, the Weekender Kit, and the rest of our recovery lineup online or through your local ARB dealer.
