Hey everyone, it’s xipoqix here!
Our new xipoqix Wireless Charging Pad is now officially available!
Are you tired of messy data cables tangled around the gearshift lever? Or do you worry about your phone moving around while driving, causing intermittent charging and low efficiency?
Fitment Note
Fits 2024 2025 2026 Tacoma and 2025 2026 4Runner. Supports mainstream brands such as iPhone, Samsung, etc. Compatible with both bare phones and magnetic cases (Note: Standard non-magnetic phone cases are not supported).
Product Link: https://www.amazon.com/dp/B0HJLXBTCW
Small Details That Matter in Daily Use
1. Dual Magnetic Wireless Charging
Features dual independent wireless charging modules so driver and passenger can charge simultaneously.
Built-in magnets hold phones securely in place during acceleration, braking, or cornering for uninterrupted power.
2. Raised Coil Design to Protect the Camera Lens
The charging module features a raised design that perfectly avoids the phone’s rear camera, effectively reducing the risk of scratches on the lens.
3. Say Goodbye to Tangled Cables—Keep Your Car Neat and Tidy
Eliminate tangled charging cables on the center console. Simply place your phone down to charge, keeping your car’s interior neat and tidy at all times.
4. High-Quality TPE Material, Easy to Clean
Uses high-quality TPE material, with good flexibility and shock absorption effect. The surface is waterproof and stain-resistant. When there is accumulated dust or stains, just remove the charging module and wipe it.
5. Adhesive Backing, Plug-and-Play
Just peel off the adhesive on the back, stick it to the storage compartment, and connect the included charging cable to the vehicle power supply to use.
Would you install this wireless charging pad in your Tacoma?
With two charging positions, both the driver and passenger can charge their phones at the same time. Would that be useful for your daily drives?
Join our xipoqix Tacoma Club for the latest product updates, exclusive discounts, and occasional opportunities to test new products.
Fitment Note
