Bed organization, Tonneau Cover and tie down recommendations for transporting wheelchair
zzneonzz
Tim
Tennessee
I'm trying to figure out how to address an issue I'm having and hope someone here can offer some advice. I have a need to keep a wheelchair in the bed of truck and I'm trying to figure out how to keep it from sliding around the bed while driving. My last truck was a 2015 Nissan Frontier with a tonneau cover and the Bed Extender used the rail system so I was able to set the bed extender so that it would old the wheelchair near the bed and kept it stationary. The Tacoma bed extender however looks like it mounts to the bed and not the rail so I think that option is out. So I was thinking of getting the cargo divider for the Tacoma and use it like I did the bed extender on my Frontier but I'm not sure that is going to be the best option since I am currently planning on getting the Bakflip MX4 when it is released and was looking at previous model's installation and it appears it drops the rail section down a bit so I am unsure if it the cargo divider will work with the lower rail hight. Does anyone know if the previous model Tacom's the cargo divider could be used with Tonneau covers specifically the MX4 (I'm open to other tonneau cover options.) The wheelchair will be folded down and laying on the side so it will fit under a cover but because it lays on the wheel it has to have something holding it in place to keep it from sliding and spinning around. So if the cargo divider isn't a good fit does anyone know of some quick attach/detatch tie down straps that can be used to secure it during transport? I appreciate any help in getting this figured out.
R.A.N.M.J.
Rick
Dallas
2021 Bronco, 2023 4Runner, 2024 Tacoma
Are you completely opposed to hitch mounted solutions? If not, they are relatively inexpensive and are easy to put on and take off. Plus they'll keep the WC from getting damaged. You can also buy WC covers and a rope lock to keep it secure.
That being said, if you must store it flat in the bed under a cover, real truck offers a bed divider that can be used for your purposes, but it'll be more expensive than a hitch mounted solution:
https://realtruck.com/p/roll-n-lock-cargo-manager/rnl-cm532/?utm_source=google&utm_source=google&utm_medium=organic&utm_medium=cpc&utm_campaign=free-pla&utm_campaign=RT GA PMax ACQ Promo Pixis&utm_content=surfaces&gad_source=1&gclid=CjwKCAjwuJ2xBhA3EiwAMVjkVIB8ppNY5cezMkNQCxQiUU_wiIZJJlPIExstppOLP8l2cOaReDCCiRoC1sMQAvD_BwE
With that one, you can push it all the way towards the tailgate and it has tie downs. Some velcro straps from Amazon will work nicely to keep the WC from sliding laterally.
It also rotates horizontally, which could help you in this situation.
I would also recommend a rubber bed mat of some kind. it doesn't have to fill the bed, just enough to put the WC on.
zzneonzz
Tim
Tennessee
Thanks!! I’m trying to avoid a hitch mount system so i can keep the truck in the garage. Using that i would have to park in the driveway or install/remove it every time we went somewhere
That cargo divider looks perfect! Does it work with the Toyota rail system though? I only saw it mention the rock-n-lock track system.
I agree even with the spray in bed liner i think a rubber bed mat is going to be a good idea and probably going to order the Toyota mat since everyone seems to love it.
R.A.N.M.J.
Rick
Dallas
Oh, sorry, I guess I don't know why I thought you were using roll-n-lock tonneau.
Here's an alternative:
https://theyotagarage.com/products/toyota-bed-cargo-divider-2024-toyota-tacoma
More expensive and doesn't flip up but, it uses the factory rails.
Goriders
2024 Tacoma Sport Plus
I bought the OEM tonneau and cargo divider. You have to cut 3/4” off each end of the divider to get it to fit but it works great.
zzneonzz
Tim
Tennessee
Thanks i had asked the dealer if there were any conflicts and they said no but now i have the tonneau cover installed but was wondering why the divider wouldn’t fit it looked to be about half an inch or so to long to fit.
Goriders
I just cut both ends with a hack saw.
2024 Tacoma Bed organization, Tonneau Cover and tie down recommendations for transporting wheelchair IMG_2846
Goriders
I cut 3/4” off of each end
