- First Name
- John
- Joined
- Sep 12, 2024
- Threads
- 15
- Messages
- 101
- Reaction score
- 66
- Location
- Greenwood IN
- Vehicle(s)
- F-150 Raptor, Ranger Raptor
If you don't find something you are looking for... Let us know!
Want us to start making a new part for your truck? Send suggestions to info @spvparts.com
Visit our website at-
https://specialtyperformanceparts.com/search?type=product&q=tacoma
During the holidays we want to be sure customers not only get the best PRICE, but also the best PRODUCTS.
If you think you find a better price on a COMPARABLE product or kit at an authorized competitor.
CONTACT US at: [email protected] or call or text 317-934-6778
We will attempt to meet or beat that offer for you. We can do this 99% of the time.
Not only will we be able to provide a comparable price or better, but you will also get better components in most cases with our kitted items.
While in many cases, you may find the same things such as light brands (Rigid, Baja Designs, Diode Dynamics, Morimoto, etc.) within competitors kits. The other items supplied are NOT the same.
When we claim to have the BEST Harnesses and Brackets in the industry, there is a reason, and we can back it up.
Oftentimes, competitors play on claims of X% off or Higher Percentages, when in fact, those are inflated from everyday prices. DON’T BE FOOLED BY THESE TACTICS. We will check, make sure you are getting the best deal. If you are, we can confirm it. If not, we will be sure you do. So, you have nothing to lose.
Harnesses –
Our harnesses are FULLY patented, and you will not find ANYTHING comparable out there. To fully patent a product, it must be COMPLETELY unique. Not only are our harnesses and harness system the only completely modular automotive harnesses around. So, they can plug together, interconnect and work with virtually any vehicle, light brand or even components in the vehicle such as running lights and reverse triggers. But they are also of the ABSOLUTE Highest grade.
If you don’t know what you are looking for, you may never know the difference. However, we will illustrate some key things to look for.
First, we use INDUSTRIAL Grade High Temp wiring. This wiring is the same grade or higher that comes in your vehicle and commercial vehicles. It is rated 200 deg Celsius. Which is equal to about 390 degrees Fahrenheit. Competitors use standard “Automotive Wiring” which has a temperature rating of 105 degrees Celsius. Which is equal to 200 degrees Fahrenheit. That means our harnesses can withstand almost 2X the temperature of the standard grade wiring used by the competitors. In addition, the coating used in our harnesses is flame retardant. Where the standard grade wire insulation used by competitors actually burns. (You can see this in our video demonstration)
Next, is the coating used to protect the harnesses. The first line of defense. We use a HIGH TEMP Loom and manufacture grade harness wraps. Competitors use lower grade PVC tubing or worse yet, braded wraps. You will notice this wrap because you can see the wire through it. These PET sleeves are intended for INTERIOR use. Not exterior where heat and other factors come into play. If your vehicle manufacture didn’t use it in your engine bay, then there is a reason. So why do others use this for exterior harnesses? Simple answer. IT’S CHEAP. We only use the HIGHEST quality wire, loom, and connectors.
US Patent: US11699537B2
Brackets –
We feel our brackets are of the highest quality, fit and finish as well. This is because we spend hundreds of ours making sure the fitment and adjustability is better than ANYTHING else out there. We often take longer to bring something out because we don’t put anything out that is not PERFECT. We guarantee the fit and adjustability will be as good or better than ANYTHING comparable.
Quality wise, we only use stainless steel for our brackets and hardware. While others may use mild steel, or even if they do use stainless steel on the brackets. They often shortcut with “Zinc Coated Steel” hardware. Of course they won’t advertise this. You will see the rust though at some point.
Our brackets are so well thought of, we even produce some for companies like Rigid Industries.
Check out the Durability test video on our harnesses.
(*Price Match Guarantee - See below)
Upcoming & Scheduled Black Friday Sales
(Sales By Vendor):
SPV Parts
(11/12-12/04)
Up to 30% or more off SPV Light Kits
Up to 20% or more off Brackets, Harnesses & Accessories
Up to 50% or more off of clearance & Open Box
Baja Designs
COMING SOON!
(Contact us to reserve your wish list)
info @spvparts.com
KC Hilites
(11/12-12/02)
15% Off Everything
Morimoto Black Friday Sale
(11/22-12/03)
20% Off Everything*
(*Some exclusions apply)
Diode Dynamics Black Friday Sale
(11/22-12/03)
20% Off Everything
Form Lighting Black Friday Sale
(11/22-12/03)
15% (Or More) Off Everything
(Discount varies by SKU)
Roush Black Friday Sale
(11/28-12/02)
Up to 10% Off Select Items
__________________________________________________________
Earlybird BYO Special Offers (11/14-11/27)
*Special Offer #1 - Build Your Own Fog Kit
Buy 3 Pairs of lights, get FREE SPV Parts Brackets and Harness
(*Some Exclusions Apply)
1. Select Your Lights: (Select 3 pairs or 6 individual lights)
Individual Pod Lights and Light Pairs
2. Select Your Harness:
SPV Parts Triple Pair Fog Harness
3. Select Your Fog Brackets:
SPV Parts 2021-2025 Bronco Triple Fog BRACKETS
SPV Parts 2017-2020 Gen 2 Raptor Triple Fog Light Brackets
SPV Parts 2021-2024 Gen 3 Raptor Triple Fog BRACKETS
*Special Offer #2 - Build Your Own A-Pillar Kit
Buy One+ Pairs of Lights, get 50% Off Your Choice of SPV Parts Brackets & Harness
1. Select Your Lights: (Select at least one pair or two individual lights)
2. Select Your A-Pillar Harness:
SPV Parts A-Pillar/Ditch Light Harness
3. Select Your A-Pillar Brackets:
SPV 2021+ Bronco Standard A-Pillar/Ditch Light Brackets
SPV 2021+ Bronco NEW MODULAR A-Pillar/Ditch Light Brackets
SPV Heavy Duty 2021+ Raptor / F-150 A-Pillar Mounts
SPV Standard 2021+ Raptor & F-150 A-Pillar Mounts
SPV 2017-2020 Raptor/2015-2017 F-150 A-Pillar Mounts
SPV 2019-2023 Ford Ranger A-Pillar Mounts
Rigid 2021+ Ford Bronco Dual Pod A-Pillar Mount Kit
*Special Offer #3 - Build Your Own Light Bar Kit
Buy One or More Light Bars, get 50% Off Your Choice of SPV Parts Brackets & Harness
1. Select Your Lights: (Select at least one light bar)
Bar Lights LED | LED Light Bar For Truck | Truck LED Light Bar
SPV Parts STANDARD Duty Light Bar Harness - SPV Harness System
SPV Parts HEAVY DUTY Gauge Light Bar Harness - SPV Harness System
SPV Parts SHORT Light Bar Harness - SPV Harness System
3. Select Your Brackets:
SPV Parts 2017-2020 Ford Raptor Bumper Bracket Light Bar Kit
SPV Parts 2021+ Ford Bronco Modular Bumper Light / Light Bar Mounts
SPV Parts 2021+ Gen 3 Ford Raptor Bumper Bracket Kit 40" & 50" Light Bars
SPV Parts 2021+ Ford Bronco Roof Line HIGH Light Bar Mount Kit
*Special Offer #4 - Free Gift Card with Purchase
Buy Any Addictive Desert Designs (ADD) Bumper or Rack,
Get a Free $100 SPV Parts E-Gift Card (Discount Applies at Checkout)
1. Select Your ADD Bumper or Rack:
Ford Raptor & Bronco Bumpers
Ford F-150 Bumpers
Ford Super Duty Bumpers
Ford Ranger Bumpers
Jeep JK Bumpers | Jeep JL Front Bumpers
Toyota Bumpers | Toyota Tundra Bumpers | Toyota Tacoma Bumpers
Chevrolet Bumpers | GMC Bumpers
Dodge Ram Bumpers | Ram 2500 Front Bumpers | Ram 1500 Bumpers
2. Add a $100 SPV Parts Gift Card To Cart For Free
SPV Parts Online Store $100 E-Gift Card
(11/14/2024-12/04/2024)
*(Exclusions Apply)
If there is anything missing from our website that you would like to purchase, please just let us know and we can get it added for you!
– Price Match Policy –
(Sales By Vendor):
SPV Parts
(11/12-12/04)
Baja Designs
COMING SOON!
info @spvparts.com
KC Hilites
(11/12-12/02)
15% Off Everything
(11/22-12/03)
20% Off Everything*
(11/22-12/03)
20% Off Everything
(11/22-12/03)
(11/28-12/02)
Ford F-150 Bumpers
Ford Ranger Bumpers
*(Exclusions Apply)
Harnesses –
Brackets –
