Need Rear Dash Camera Advice
EastonTaco
Venice FL & Easton PA
I installed an OEM front dash camera on my Sport. I knew it did not have a rear facing camera but I liked the factory look and it works great. I would like to install a stand alone rear dash camera and asking for advice from anyone who has already done this or camera recommendations for a rear camera that does not need to connect to a front camera. It seems that most rear cameras require connection to the front camera as the system base.
tgrneal
Aaron
Huntsville, AL
Tacoma Trailhunter
I installed the Garmin mini. That’s a standalone camera. I hardwired it and stuck it to the drivers side glass since I have the sliding window.
EastonTaco
EastonTaco
That
I was actually thinking the Garmin would work. Where did you grab power from in the back?
tgrneal
Aaron
Huntsville, AL
Tacoma Trailhunter
I ran the wires all the way to the front passenger fusebox under the dash. I used AI to tell me which fuses were non-critical. Buy a hardwire kit and some fuse taps and the length of wire should be just enough. I have a post where I explained my process.
