Stock Height?
Newtacointown
Toyota
Toyota USA website indicates the stock height as 74.6 inches for the off road yet Toyota Canada lists as 70.6 inches. That’s 4 inches of discrepancy… could it be the U.S number includes the shark fin and Canada doesn’t? Does anyone with a stock off road mind double checking the height from level ground to the top of the cab and also to the top of the shark fin?
I have a GFC camper topper coming so the shark fin should tuck under the lip of the closed GFC. Just praying I can fit in my 81 inch high parking garage with 33 inch tires, no extra lift and the GFC ??
2ndGen2TrlHntr
Alex
Denver, CO
Here is what I can tell you. I have a second gen but I believe ride height is likely similar.
I have a 3 inch lift, 33’s, RSI topper with double stacked load bars, CVT Mt Hood tent, bars on the top with a ski rack, Rotopax, and maxxtrax and I am still under 80”. My garage is 80”. My buddy has a 3rd gen with Lone Peak camper which is what I’m getting for my Trailhunter and similar to the GFC and he’s several inches shorter since it's all in one vs my tent that sits on loads bars on the RSI. My plan is to do the Trailhunter with 35's and the Lone Peak and I'm 99% sure I'll still be below 80". I won't has as much stuff on top either so I will be regaining those inches as well.
Planoman
DFW, Texas
The height of my 24 stock off road is about 71 inches from ground to top of cab. The shark fin antenna is a tad over 2.5 inches additional. So 73.5 minimum. I would go with the 74.6 inch figure.
Newtacointown
Toyota
Great thank you!
Newtacointown
Toyota
Judging by some info I got from GFC it is 6 inches thick with the tent closed and sits .78 inches above the shark fin. Going by the 4th Gen listed stock ride height of 74.6 looks like I won’t fit in my parking garage with the GFC. Might want to double check your set up as well if parking in your garage is important. It appears the 4th Gen is significantly taller than the 3rd Gen
