The Truck-Bed Crawl Nobody Asked For
TRUMGETA
CHINA
There is a very specific moment every pickup owner eventually experiences:
The tool, cooler, grocery bag, or recovery kit you need is sitting all the way against the cab.
You can reach for it and come up six inches short, climb into the bed on one knee, or attempt that awkward tailgate stretch that makes you question every life decision leading up to this moment.
A pickup bed offers plenty of cargo space. Unfortunately, it does not always offer convenient access to that space.
That is the problem the Trumgeta Slide-Out Truck Bed Cargo Tray is designed to address.
A Simpler Way to Use the Bed You Already Have
The Trumgeta Slide-Out Truck Bed Cargo Tray is not a permanent drawer system or a full-bed mechanical platform. It is a relatively lightweight slide-out cargo solution that brings stored gear closer to the tailgate.
The tray measures 57.5 inches long, 21.5 inches wide, and 1.7 inches high, with an internal loading area of approximately 52.9 by 16.9 inches. At 23.9 pounds, it can add easier cargo access without turning the bed into a major construction project.
Its biggest value is straightforward:
You can reach cargo without climbing into the truck bed every time.
That may sound like a small improvement, but it becomes noticeably useful when the bed regularly carries:
  • Tool cases and work equipment
  • Coolers and grocery bags
  • Camping totes
  • Fishing equipment
  • Recovery gear
  • Equipment that somehow becomes heavier once it slides toward the cab
For people who use their trucks every day, reducing one unnecessary climb can be surprisingly satisfying.
Two Trays, Two Different Jobs
One of the more useful features is the dual-tray layout.
You can pull out one side while leaving the other side packed, rather than moving or unloading the entire setup to reach a single item. One tray could carry work tools, while the other handles camping supplies, groceries, or everyday equipment.
That flexibility matters because most truck beds do more than one job.
Monday through Friday, the bed may carry tools and supplies. On Saturday, it holds camping gear. By Sunday afternoon, it contains a cooler, two folding chairs, muddy boots, and at least one object nobody remembers packing.
Separating those loads can make the bed feel less like a large outdoor junk drawer.
Keeping Cargo Under Control
Mixed loads do not move as one neat unit.
A hard tool case, soft recovery bag, cooler, and plastic tote will all react differently when the truck turns, brakes, or travels over rough ground.
The tray includes stainless-steel D-ring anchor points and four ratchet straps, providing several places to secure different types of cargo. Its four-point mounting system attaches to the truck bed’s existing tie-down locations, so installation does not require drilling.
That no-drill setup also makes the tray easier to remove or reposition when the bed needs to carry something larger.
It is a practical distinction: not every truck owner wants a cargo system to become a permanent part of the vehicle.
Designed for Wet and Dirty Gear
Truck beds rarely stay completely dry.
Rain gets in. Fishing gear comes back wet. Camping equipment collects mud. Water can even find its way under some tonneau covers, because water has apparently made defeating truck accessories a personal hobby.
The Trumgeta Slide-Out Truck Bed Cargo Tray uses a fast-drain channel with low-point drain holes to help move water away rather than allowing it to remain trapped beneath the cargo. The main tray is made from a textured PE composite intended for outdoor use.
It will not magically clean wet boots or muddy gear, but it gives water somewhere to go and makes the cargo surface easier to rinse after outdoor use.
The wrapped edges are another small but thoughtful detail. They help reduce sharp contact with hands, bags, tool cases, golf equipment, and other cargo as items are loaded or pulled across the tray.
Learn more.
Where It Makes the Most Sense
This tray will not replace every truck-bed storage system.
Owners who need completely enclosed storage, maximum theft protection, or a heavy-duty commercial drawer setup may still prefer a permanent system.
The Trumgeta Slide-Out Truck Bed Cargo Tray makes the most sense for owners who want:
  • Easier tailgate-side access
  • Flexible organization without permanent modification
  • Separate areas for different types of cargo
  • Tie-down points for mixed loads
  • A removable system that fits many midsize and full-size pickups
Trumgeta states that it fits most midsize and full-size pickup beds using a four-point ratchet-strap mounting method. Since bed dimensions and factory tie-down layouts vary, measuring the usable bed space before ordering is still the sensible move.
Measure twice, avoid an oversized delivery-shaped surprise once.
The Practical Value
The strongest argument for a slide-out cargo tray is not that it completely transforms the truck.
It is that it removes several small frustrations:
Less crawling into the bed.
Less reaching over the tailgate.
Less cargo shifting around.
Less unloading one pile to reach another.
It makes the existing bed space easier to use without demanding that the owner redesign the whole truck.
That is not the flashiest upgrade in the parking lot, but it may be one of the upgrades you notice every time the tailgate comes down.
Your Turn
What is the one item in your truck bed that always manages to slide all the way toward the cab—tools, coolers, groceries, or something stranger?
Share your answer in the comments. We will select one eligible commenter to receive a high-value coupon toward the Trumgeta Slide-Out Truck Bed Cargo Tray.
Apparently, complaining about hard-to-reach cargo may finally pay off.
TRUMGETA
TRUMGETA
CHINA
We’ve been thinking about the dual-tray setup from a real-use perspective.
If this were in your Tacoma, how would you divide the two sides?
Left tray: tools and recovery gear
Right tray: cooler, groceries, and camping supplies
Or would your setup look completely different?
There is no wrong answer—although putting everything loose in the bed and hoping it stays organized has historically produced mixed results.
