Has anyone had an issue with their light bar not working? I’ve put my high beams on and it won’t turn on. Any advice would be appreciated
Is your switch in the right position?Has anyone had an issue with their light bar not working? I’ve put my high beams on and it won’t turn on. Any advice would be appreciated
high beams?Is your switch in the right position?
I don't have a Pro, but from what I've seen (IIRC), there should be a switch where your Aux switches are that has to be turned on as well.high beams?
Yes sorry, I’ve tried the light bar button and nothin. I don’t use it very often but just tried it and no luckI don't have a Pro, but from what I've seen (IIRC), there should be a switch where your Aux switches are that has to be turned on as well.
When your light bar switch is on, turn on your brights. That should turn on your light bar. If that doesn't work, check your fuses or take it to the dealership.Yes sorry, I’ve tried the light bar button and nothin. I don’t use it very often but just tried it and no luck
Yep I was gonna suggest fuses next.When your light bar switch is on, turn on your brights. That should turn on your light bar. If that doesn't work, check your fuses or take it to the dealership.
Any idea where the fuse would be for the light bar?Yep I was gonna suggest fuses next.
Glad they're getting it taken care ofTook to dealership today and the light bar is faulty, have to order me a new one
