Turbo engine break-in
Toy@home
Dale
Austin.Tx
2024 Tacoma.. SR5..rwd
By the Manuel, it says don't gun it and don't keep it a higher speeds consistently. My question is, if I just drive it to work at an average of 50mph and then back home 65mph on the highway, is that sufficient for the break in of about 500mi. About 10 miles each way every day. Does that effect the turbo in any way. She's sittin' at 250 mi. right now. Thoughts on this....thanx..Dale
Gfenza89
Gary
2022 tacoma sr5
Page 187 in your owners manual. Break in guidance. Also guidances for cooling down after boosting on same page.
I’m amazed how little these engines use the boost. Driving around town lot of times there’s no boost at all
Deleted User 1813921
Guest
in eco mode I can keep from spooling up entirely with downshifting on hill climbing and very easy throttle inputs. But normal mode not so much and sport mode is boosted! You can keep that turbo from spooling on a manual transmission if you choose In eco mode. I like that.
Gfenza89
Gary
2022 tacoma sr5
So I guess that little 4cyl engine has enough power to keep the truck going with out using forced induction. That is a good thing for longevity and I also notice how low the rpm’s stay which is also good not over revving the engine
Toy@home
Dale
Austin.Tx
I just didn’t go above 4000 RPM and tried to vary the RPM every once in a while if using cruise.
I changed my oil after the break in period.
Was that at 1000mi....?
Goriders
2024 Tacoma Sport Plus
Think it was 2000 kms or ballpark 1250 miles
