Will 2023 wheels fit on 2024 Tacoma? Hub bore, lug bolt pattern, lug size?
bking
Bernie
2021 F150
Answered by Discount Tire below:
The 2024 Tacoma now has a different hub bore. It went from 106.1 down to 95.1
Lug bolt pattern is still 6-139.7
Lug size is 14x1.5
Has anyone heard if you can use wheels for a 2023 on the new Tacoma? I'm getting a black TRD OR and would really like solid black wheels instead of the combo wheels that come on the truck. I know eventually they will be advertised for the 24, but I work for Goodyear and can swap the BFG tires for any Goodyear tire I want within 500 miles for free so it would be nice to have them mounted to the new wheels at that time. I can actually buy the old tires back for $40/ea so long as I don't drive them to work :) so I could just take the old wheels and tires home to save for trade in time some day.
Gear_yyc
2007 Chevy Avalanche
I'm quite certain it's the same bolt pattern, but I don't think anyone has published the offset yet, unless it's in the owners manual.
jacobjohnson
jacob
Georgia
not the same. talked to local shops and they’re working on having wheels for new bolt pattern by the time trucks hit the lots.
Gear_yyc
I just checked Tirerack and they now have the 2024 Tacoma on there and they're saying 6x139 which is the same as the 2023. Looks like backspacing might be a bit different.
Discount Tire
Arizona, USA
All Things Toyota
The 2024 Tacoma now has a different hub bore. It went from 106.1 down to 95.1, the bolt pattern is still 6-139.7. Should be a solid fit. Be sure to check out our Website for more wheel options.
