Mabett
LA
www.facebook.com
2026 Tacoma TRD Sport
Hi everyone, Jeremy here.
Our new Driver-Side Dash Storage Drawer is now officially available. We finally designed it to turn the unused driver-side dash cubby into a 2-in-1 storage space, combining a quick-access key pocket with a hidden pull-out drawer.
Tacoma4G Launch Offer
Now $10.39 with code 5OD56V3M at checkout.
https://amzn.to/4e5JbQ9 👈
Turn an Unused Cubby Into 2-in-1 Storage
That small open cubby beside the steering wheel can easily become wasted space. The first thing we wanted to do was turn it into a practical pull-out drawer for coins, cards, and other small items.
But we didn’t stop there.
We added a quick-access key pocket on the outside, creating two storage areas for two different uses. Your key stays within easy reach without opening the drawer, while the drawer remains available for coins, cards, and other small items you’d rather keep tucked away.
The key pocket has its own dedicated space, so it doesn’t take away any of the storage space inside the drawer.
A Few More Details
Inside the drawer, a silicone pad helps keep coins and other small items from sliding around or rattling against the base. We also added foam strips around the outer housing to help the organizer sit more securely inside the factory cubby when you open and close the drawer or drive over rougher roads.
Fitment & Feedback
Fits 2024–2026 Toyota Tacoma models with the open driver-side dash cubby. Not compatible with trucks equipped with a factory trailer brake controller in this location. Please check your dashboard configuration before ordering.
What do you normally use this little dash cubby for? Would you use the outside pocket for your key, or for something else?
Feel free to share your thoughts below. You’re also welcome to join the Mabett 4th Gen Tacoma Garage for more new product updates.
Mabett
Mabett
LA
www.facebook.com
Good idea. I have a brake controller so can’t leverage this but nice to see some out of the box thinking here.
:fistbump: :fistbump:
