TRUMGETA
CHINA
Hey Truck Enthusiasts,
Looking for a versatile and durable roll bar rack that fits your full-size or mid-size pickup? Check out the TRUMGETA Adjustable Truck Bed Roll Bar Chase Rack—designed to fit trucks like Ford F150, Toyota Tacoma, Chevy Silverado, Dodge Ram 1500, and most bed rails with a width adjustment range from 58.8" to 66.8".
Here’s what makes it stand out:
  • Heavy-Duty Steel Construction: Made from industrial-grade steel with a powder-coated black finish to resist rust and corrosion—ready for hauling lumber, ladders, or contractor-grade gear.
  • Rear Window Protection: Special crossbars are angled to deflect long loads while keeping your rear window fully visible, making it a critical safety upgrade.
  • Secure Drill-to-Mount Installation: With included step-by-step visual guides and lifetime tech support, you can install it yourself in under 3 hours using basic tools.
  • Anti-Cargo Collapse Design: Reinforced honeycomb side panels prevent shifting loads and reduce wind resistance, meeting DOT safety standards.
Special Offer: Use promo code RACK15 for 15% OFF your order! Hurry, offer ends June 25th!
If you want a professional-grade, customizable truck bed roll bar that offers ultimate protection and utility, this is it. Perfect for both work and play!
Got questions or want to share your installation experience? Drop your thoughts below!
Automotive Exterior Grille Bumper Hood Pickup truck
Vidman
Rick
Mass
That’s definitely ugly
WhiskeyTallwood
Matt
There's probably 10,000 dudes in Texas who drive pristine F250s that have never had so much as a beer can, let alone an actual tool, touch the truck bed that would salivate over this.
Nacho TacoMan
Paul
2025 Tacoma Limited. 2018 BMW X5 335d
A definite upgrade to the horrendous weak cheesy wannabe that comes standard on the trail hunter.
