nurp42
TRD PreRunner
'24 PreRunner
So after having spent what seemed like forever doing research and weighing the pros and cons of bed rack systems and tonneau covers that can be used together, I got the BAK Revolver X4ts cover and the Elevate rack from Realtruck. There were a few options that looked really good, but the primary reason for going this route was that it didn't take up bed space with a canister of any kind and did not require changing the location of the bed rails at all (which was important since I wanted to be able to keep the Molle panels in the bed as useable as they had been before installation). When the cover is closed, it's almost flush (hardly above bed level) and when open doesn't block rear view. The rack system seems very solid and the integration between cover and rack is good. Since posts I found here were such an excellent resource for me, thought sharing this post may be helpful to others.
Pics below are full side view, tighter shot of the Elevate rack (there are three height setting to choose from and mine is at the middle setting----it can be raised a little more than another 4 inches from there if need be), pic of Revolver cover in closed position, and pic of bed w/ cover open.
2024 Tacoma Finally pulled the trigger on bed cover & rack combo: BAK Revolver X4ts + Elevate rack from Realtruck tempImageit0ROs
2024 Tacoma Finally pulled the trigger on bed cover & rack combo: BAK Revolver X4ts + Elevate rack from Realtruck tempImageY7LKOe
2024 Tacoma Finally pulled the trigger on bed cover & rack combo: BAK Revolver X4ts + Elevate rack from Realtruck tempImagep4wIE9
2024 Tacoma Finally pulled the trigger on bed cover & rack combo: BAK Revolver X4ts + Elevate rack from Realtruck openbed
nurp42
nurp42
TRD PreRunner
'24 PreRunner
Found these tie-downs on Amazon that fit into the t-track slots also.
2024 Tacoma Finally pulled the trigger on bed cover & rack combo: BAK Revolver X4ts + Elevate rack from Realtruck tempImagewyB4qZ
Benny
Jay
Oregon
I have the same tonneau cover and like it a lot. KĂĽat just came out with an adapter for this system so I eventually want to get the IBEX bed rack.
doyleaa
Aaron
PA
Can you share the link for the adapter? The ibex will work with this cover?
doyleaa
Aaron
PA
Thanks bud!! I appreciate it....did this just get released for the revolver ? I dont recall seeing it as a compatible cover when i started looking.
Benny
Jay
Oregon
Yes! It’s pretty new… I was going to see if a buddy could fabricate something for me but I’m glad Küat finally put something out.
doyleaa
Aaron
PA
No issues with the revolver bed cover?
Benny
Jay
Oregon
Nope! It is not water tight, but I knew that when buying it. You will get a few drips in heavy rain but nothing horrible. Anything that has to be dry goes in a covered bin or in the cab. Otherwise I love the low profile and t-slot rails for future functionality (and it doesn’t take up any space in the short bed).
