What’s your opinion on aluminum rock sliders?
nicholo85
nicholo
canada
2024 tacoma
Hey guys, just want to know what your opinions are on using aluminum rock sliders. I'm not really planning on doing any super technical off roading or rock crawling, but want to put some protection to avoid damaging the body.
This is the one I'm considering: https://greenlaneoffroad.com/4th-gen-toyota-tacoma-2024
Thanks in advance!
grizzlyoutlaw
MTN WEST
TACOMA
I think they sound perfect for your need. Description says "*Will protect vehicle from rocker damage but not designed to be used as a high lift jack point. " So the real question is; Are you even going to have a high lift jack on your truck? If so, you can put it under the sliders to lift the truck for trail repairs or changing tires. I have personally have never had to do that and will probably just get an exhaust air jack to throw under the frame. example
exhaust air jack
Visa_Declined
OKC
TRD Off Road
Just my opinion, but those are ass. They're put together with a bunch of smaller pieces of tubing, because they obviously don't have a bender. And while yes they're lighter than steel sliders, they cannot support the weight of the truck, which makes them for looks only. They're charging the same price for these that companies do who make real sliders also.
nicholo85
nicholo85
nicholo
canada
2024 tacoma
I see what you mean from the renderings, but from the photo of the actual product, it looks like its bent aluminum. Would tube welding be covered up with the powder coat? It's really the weight savings I'm after.
This is the hard part for me, being a novice. I just don't know how difficult of offroading I'll end up doing. If I buy steel, but never really do trails that put the entire weight of the truck on the slider, then I'm carrying around extra protection and 120 lbs thats not needed. But if I go aluminum for light protection and end up banging it around, I'll end up having to replace it in the future.
Ugh, decisions decisions!
Greatisland
Victoria bc
www.instagram.com
2024 Tacoma offroad
The white truck in the photos is mine, I have full confidence In those sliders. I did have steel ones on my previous vehicle but I wont be wheeling the new one as hard. Its for the odd occasion I need to slide. To me weight savings is more important than full sliders so that's why I went the aluminum route this time.
Visa_Declined
OKC
TRD Off Road
The trucks are already heavy pigs anyway IMO.
malore
Oregon
What'd you end up going with here? I like the idea of weight savings. I've had 6 Tacomas and I've never wheeled them to the point where I need a rock slider to protect the truck from giant boulders like the true wheelers out there do. I like them for protection against flying rocks, sand, salt and cinder. Plus they look rad. My off-roading usually consists of logging roads, beach driving and a couple yearly Baja trips. I don't really go out and rock crawl. Anyway, interested to hear what you went with.
nicholo85
nicholo85
nicholo
canada
2024 tacoma
I ended up with steel. I've been doing more technical stuff and steel will be vastly better from a durability standpoint.
From what you've described your usage is, aluminum is probably the way to go.
