- First Name
- Anthony
- Joined
- Jan 11, 2025
- Threads
- 11
- Messages
- 628
- Reaction score
- 442
- Location
- Aberdeen Wa
- Vehicle(s)
- 2024 Toyota Tacoma TRD Off-Road
Watch the video on stock top hat failure at running for tacos ? ? ? and see if you want to pack anything more in the stock trd off-road shock. The top hats fail then you have to buy another part. Then your travel's reduced .Functionally, a preload spacer and a longer spring are going to do the exact same thing. Unless you want a different spring rate due to a lot of extra weight, I can’t see any reason to buy new springs over a preload spacer. Both options will reduce your shock travel though, however, the TRD off road model has extra travel for the sway bar disconnect option due to the remote reservoirs.
With the integral bump stops on the new generation shocks, the downside to a top hat spacer is now gone too. You also won’t lose any shock travel with a top hat spacer. Provided your stock ball joint angles aren’t too out of whack.
Basically, you end up with a suit and tie lift that creeks every time you hit a bump.
