gofastdan
I have a Thor's Lightning Bolt dual air compressor. Once you start shopping you'll realize that there are at least half a dozen competitors all selling the same unit. Even Napa sells effectively the same thing. In retrospect Vevor's is probably the best deal (if it's in stock). Anyway, it's a great unit and will inflate my 34" tires (all four at once) from 20psi to 32psi in ~2:30.
The trade-off is that these units are big, heavy and hard to store. I had mine under the floor of my camper drawer build-out but it wasn't convenient to get to so I never used it. I've been contemplating doing a permanent install for some time and finally got around to it this past week.
I decided to put it between the bed and the body of the truck on the back drivers side. All four corners of the truck have enough room between the body and the bed to hide a dead body in. My plan was to install the air chuck and switch in the cubby where the 12v power is but you'll see that didn't work out. Still, I'm happy overall with the finished result.
First, I had to come up with a mount for the compressor. I thought about using a HF Apache case, and the compressor fit in the medium case, but I ended up deciding not to try it for two reasons. First, the compressor weighs close to 20lbs and I was afraid the plastic case wouldn't last long with all the forest service roads I drive on. Second, I couldn't figure out how to mount the compressor in the case and then get the case mounted to the side of the bed.
In the end my friend Upper Left Adventures had some steel laying around and welded me up a mount. It's solid and should hold up for many years.
2024 Tacoma Large Dual Piston Air Compressor Install PXL_20250726_202634113
2024 Tacoma Large Dual Piston Air Compressor Install PXL_20250726_202733305
I then had to attach the mount to the side of the bed. There's fairly easy access between the fender and the bed by removing the fender support brackets. I used the project as an excuse to buy a right angle drill attachment to help me drill the holes and that worked great. I cut some aluminum bar I had and drilled holes it in to support the bed. It would probably be ok with some fender washers but I'm a little leery of the bed cracking from the weight hanging on it all the time. With the bar spreading the load I'm not worried at all.
2024 Tacoma Large Dual Piston Air Compressor Install PXL_20250726_221703356
2024 Tacoma Large Dual Piston Air Compressor Install PXL_20250726_223806891
I should mention that I decided to mount the compressor upside down. This will allow me to access the dust covers and filters from underneath the truck when they need cleaned (which they will often). It's easy enough to reach up from the bottom and screw the dust covers off.
It was a hassle to mount the compressor but with me underneath the truck and my son reaching in from the top we managed to get it done with minimal cursing. This is definitely a project you need help with though!!!
2024 Tacoma Large Dual Piston Air Compressor Install PXL_20250728_002005608
From here it was easy. I thought. Here was the plan.
2024 Tacoma Large Dual Piston Air Compressor Install PXL_20250727_003438650
2024 Tacoma Large Dual Piston Air Compressor Install PXL_20250727_003451898
This was great until I went to install it! Oops. Lessons were learned.
First, there's a structural support rib on the back side of the bed right where the air chuck and switch would have to go and, more importantly, the wiring loom for the 12 volt USB and whatnot is on the opposite side of the enclosure. You have to angle the enclosure in order to get it in and out of the bed and there is no way to get the enclosure back in it's place in the bed with where I put the chuck and switch.
I really didn't want the switch and chuck on the other side because then it's facing away from you when you're trying to use it. Also, the air line from the compressor wasn't long enough and I didn't want to hassle with trying to replace it. My final solution was to mount the switch on the other side, but mount the air chuck straight out of the bed. It's solid and there are other items sticking out there as well so I'm not too worried about damage, but it's definitely not what I had in mind.
2024 Tacoma Large Dual Piston Air Compressor Install PXL_20250728_001914003
2024 Tacoma Large Dual Piston Air Compressor Install PXL_20250728_191719787
2024 Tacoma Large Dual Piston Air Compressor Install PXL_20250728_191710027
The only other piece is the wiring and that actually was easy. I'm paranoid so I ran 4 gauge wire in a loom to the battery rather than try to tap into power at the back of the truck. 25 feet of wire was perfect.
2024 Tacoma Large Dual Piston Air Compressor Install PXL_20250727_214448226
For the switch I simply spliced into the existing compressor switch wiring.
2024 Tacoma Large Dual Piston Air Compressor Install PXL_20250727_001110078
All in all I'm happy with the outcome. I do wish I could protect the air chuck a bit more but I think it will be fine. I'm not worried about water splashing up on the compressor. It's pretty well protected up where it is. Dust will be an issue though and I may end up coming up with some sort of filter blanket to try and mitigate dust covering the compressor but I'm going to leave it as is for now and worry about it later if it becomes an issue in the future.
tkrum015
Ted
Olympia
Great job. The Thor is a mega compressor and I love the 4 tire inflator. With that set up it takes you longer to set it all up than to inflate your tires. Maybe you should be the first to go to 37 to use that monster.
Wanderlust
Will
Denver, CO
2024 Tacoma TRD Off-Road - OTT Tuned
Nice writeup. It's nice to see other onboard air threads. I installed the ARB compressor back in February. Good to see other options.
Edit: February, not last year. 😵
2024 Tacoma Large Dual Piston Air Compressor Install 1754666295398-hl
Iqudayo
2024 Toyota Tacoma
Nice writeup. It's nice to see other onboard air threads. I installed the ARB compressor on mine last year. Good to see other options.
im wondering if that other compressor fits where you installed yours
Wanderlust
Will
Denver, CO
It'll be a tight fit. I'm not sure they make a bracket for the Thor compressor in the engine bay.
tkrum015
Ted
Olympia
Where did you get the bracket and compressor?
Halifax, NS
2025 TRD Pro
Also wondering about the bracket, also is that the dual piston arb?
Wanderlust
Will
Denver, CO
I got the bracket from Zroadz Off Road. Compressor I got it from someone that was retiring their rig. I have a small thread on my profile with some links on how I put it together.
https://www.tacoma4g.com/forum/threads/arb-air-compressor-bracket-installed.9989/
Zroadz Off Road. Yes, it's dual. The bracket will also fit the single.
Halifax, NS
2025 TRD Pro
Interesting, it says not compatible with hybrids, yet I think I have the same free space between the ECU and Fuse box as a non-hybrid, I'll keep waiting for a solution that's similar to OEM but with an ARB
bronzebeast
So Cal
2025 DCLB
So was the right angle drill just so you could drill out the through holes for the mounting bracket? If so how did you keep the bracket in place while you drilled them out? I’m looking to do something similar with a VEVO 10cfm but want the chuck coming out near the license plate
gofastdan
gofastdan
Exactly. I was drilling from the outside of the bed. Drilled the first hole and partially mounted my bracket and then drilled the rest of the holes with the bracket in place. Once I had two holes and bolts going through them then the rest were easy but there was no way I could have done it without the right angle attachment.
Technically maybe I could have done the same thing from the bed side and then flipped the mounting bracket but my drawer system is a huge PITA to pull out and with it in place I would have still needed the right angle drill attachment to drill any holes.
Plus, I've wanted the attachment for a while and this was a convenient excuse..... ;o) $40 well spent and if you don't need or want the complete kit then it's even cheaper (talking about DeWalt's attachment, which is a quality piece of kit). They do specify to use it with an impact driver. I'm not sure why but I've got a cordless impact drill so I used it and it worked great.
gofastdan
gofastdan
No way. My compressor is huge. That's why it fills so fast though. Everything is a tradeoff. There was no place in the engine bay I found to mount it that made sense.
Assuming you could find a place, Thor's Lightning does make a few brackets focused mainly on Jeep applications that you potentially could customize. They're so expensive though I think you're far better off designing your own solution and finding someone local to make it for you.
gofastdan
gofastdan
They don't. They do make Jeep specific mounts but I think it would be a waste of money to try and customize one. Just decide where you want to mount it and design your own mount and have it made locally.
