Good evening. I’m wiring up some ditch lights on my 25 TRDpro using the connection by the washer fluid. After wiring up the lights, when I tested the lights, they turned on as soon as I turned my truck on. I unplugged the connector and tested the white wire with the white/black ground and it had constant power. None of the aux switches were turned on. I moved to the larger connection (20A/40A) and found the 40A (red) was powered with the 20A ground (white/black). I’m sure it’s operator error but I will be damned if I can figure it out. Has anyone seen this and know what I’m doing wrong. I ended up using the 40/20 wires since the ditch lights are not even close to 20A. Plus it’s Aux 1 which is what I wanted anyway.
