New Wheels and Tires: Method 705 +35 offset wheels and Nitto G3 285/70/17 tires
shackley
Bernalillo County, New Mexico
www.swxrflab.net
2026 Tacoma TH (Ice Cap); 2024 RAV4 Prime
I finally decided on wheel and tire combo. Thank you to everyone for advice and pics.
Wheels: Method 705 +35 offset
Tires: Nitto G3 285/70/17
Looks good. Have you got it to full articulation? I'm considering the same set-up with a 35mm offset and 285/70/17 MT Baja Boss A/Ts. With tires wider than stock with +20 mm offset and narrower tires by an inch or so I'm wondering about rubbing at full articulation and an unlocked stabilizer bar. Any info would be appreciated.
PNWkip
2025 DCLB SR5
SIIIIIIIIIICK! Swapping out to the G3 tomorrow.
They look really good. How's the road noise ?
Mtnbikes
Mtnbikes
Minnesota
There is no rubbing with my set up. I’ve had it full articulation going up and down my driveway at the curb and there is plenty of room. I was initially worried about the inside dimple of the Canadian mud guards I have allowing enough clearance. However, happy to report no issues. Here’s a couple pics to see how the front tire sits.
2024 Tacoma New Wheels and Tires: Method 705 +35 offset wheels and Nitto G3 285/70/17 tires imag
Mtnbikes
Mtnbikes
Minnesota
No bothersome road noise from these. I would say a little quieter than my previous Falken Wildpeak AT4W. Nitto did a great job redesigning this tire from the G2 generation. I’m very happy with my wheel/Tire combo, especially the offset. Plus, being weight conscious,I did not add much weight to the truck. Perfect in my opinion and exactly what I was looking for.
PNWkip
2025 DCLB SR5
I'm REALLY excited to get mine. I never did hear back from anyone about true measurements v.s. spec sheet so went with the smaller 265/70R18 which should be close to yours. I am just AMPED after seeing this haha I had now to choose between the sidewalls! I had only seen anyone do the lightening bolt side. Looks great like this!
ChuckDBike
MN
24 TRDOR 6MT
Looks good! I am also from MN with a silver 24 OR and am considering the Alu-cab and similar wheels. We may run into each other at a local MTB trailhead, especially if you go to Localized!
