- First Name
- John
- Joined
- Sep 12, 2024
- Threads
- 17
- Messages
- 116
- Reaction score
- 76
- Location
- Greenwood IN
- Vehicle(s)
- F-150 Raptor, Ranger Raptor
So we have had these in since October, but never really let you guys know.
This is the Tacoma version of our Headlight/Parking light adapters.
This is part of our SPV Patented Plug N Play System. We have MANY versions of these for a RANGE of vehicles. You can watch this video to learn more-
The Adapter allows plugging into the factory connector without splicing for powering backlights on lights like A-Pillar Light Kits, or Fogs or light bars. You can also power your "RAPTOR STYLE" Grille Marker lights.
It is plug n play, so no cutting or splicing. Works like factory. So when the parking lights are on, you are powering whatever you connect with it.
Do keep in mind though that this is intended for LOW power lights like backlights or marker lights. Though with the use of one of our relay adapters, you can add up to 25 amps from that trigger.
Here is a link to the Headlight /Parking Adapter- (Link)
If you use one of our SPV Patented harnesses (such as an A-Pillar Harness) (Link) Then the adapter can just plug directly into our harness to power backlights on the lights you add to your truck.
If you want to plug it into anything else, such as your own Marker Lights. You will want one of these add on single pole Female Connectors (Link)
So if you added the A-Pillar Harness (above) and these Rigid Brackets (Link). and these Rigid 360 Lights (Link). You would have a light setup with backlights powered automatically with the vehicle and the main light on a switch.
Of course we have the complete Tacoma SRL Rear Light kits for both the Flush Mount cut outs on the ARB Bumper- (LINK) and the standard bumper for the UNDER side- (Link)
We also have our Harnesses available individually for JUST the Tail Light Adapter (Powers reverse trigger and running light) (Link)
As well as our Short Harness WITH tail light adapter. This powers 2 Lights and the backlights from the reverse and running light signals (Link)
You can see all of our harnesses in the system here- (Link)
The harness system is a series of plug n play harnesses allowing you to connect and build any custom harness configuration you can imagine. No matter what the project. Just like Legos... You can build and connect to make anything you can imagine. All plug n play with just 2 exceptions. Some lights don't have connectors. So we provide them in the harness kit to add to your lights and some vehicles don't have connectors on the switch wires. So we provide add on connectors so they will.
You can learn more from this video from the Motor Trend Channel-
We will be releasing some new adapters for the Tacoma soon. Such as a replacement for the patch pig tail from the 5 Pin Aux switch connection under the hood to patch the 2 pin connector to the rear. This will give you connectors for all individual switch wires that you can plug into that patch with ANY switch. Not just Aux 1. And each will also just plug into our harnesses.
This is our new Pig Tail harness for the 25+ Models for the rear. This will allow you to use just one or both switches since Toyota put both Switch 1 and 2 back there now.
You can use this with or without the tail light adapter. So you truly can customize things just to your liking.
Each connection will be wired and easy to connect.
If you have any questions, please feel free to reach out to us at 317/934/6778 or email us at info @spvparts.com
You can also email us if there are products you would like to see us produce for the Tacoma or other vehicles.
John - SPV
John - SPV
