Patequila
STL
24 TRD Off-Road Premium
2024 TACOMA VIN DECODER
3TM = Toyota Mexico Baja Factory
3TY = Toyota Mexico Guanajuato Factory
J = XtraCab with GVWR below 6000 lbs
K = Double Cab with GVWR below 6000 lbs
L = Double Cab with GVWR above 6000 lbs
B = 278 hp AT (SR5/TRD Sport/TRD Off Road/Limited)
C/F = Hybrid (TRD Sport HV/TRD Off Road HV/TRD Pro/Trail Hunter/Limited)
D = 228 hp AT (SR 8AT)
E = 270 hp MT (SR 6MT/TRD Sport 6MT)
A = XtraCab
5 = Double Cab
F = 278 hp 2WD (SR5/Prerunner/TRD Sport)
H = 228 hp 2WD (SR)
J = 27x hp 4WD (SR 6MT/SR5/TRD Sport/TRD Off Road/Limited)
K = 228 hp 4WD (SR 8AT)
L = Hybrid 4WD (TRD Sport HV/TRD Off Road HV/TRD Pro/Trail Hunter/Limited HV)
N = Tacoma
_ = Check Digit
R = 2024 Model Year
M = Toyota Motor Manufacturing de Baja California Plant
T = Toyota Motor Manufacturing de Guanajuato Plant
______ = Serial Number
spenticus
Spencer
Santa Cruz
2024 Tacoma TRD ORP 1998 4 Runner SR5
What is a check digit? Is that just a filler number?
SweetDave
Paul
Birmingham, AL
2024 Tacoma SR5 4x4
So if my serial # is 000548, is this the 548th Tacoma built, or the 548th of the *trim of the Tacoma* built?
PYLDRVR
2019 Jeep Rubicon
"The check digit, found in position 9 of the VIN and compulsory for vehicles in North America, is used to validate a VIN. This is helpful for computers to immediately tell if there is an error or issue with the VIN. The check digit is calculated by removing all of the letters and substituting them with their appropriate number counterparts. You then take those numbers and multiply them against a weight factor table. You then have 16 numbers which you add together and divide by 11. The remainder is the check digit. If the remainder is 10, then the check digit is “X.""
From: https://www.cjponyparts.com/resources/check-digit-calculator
CATOY
NorCal
From what I can tell crunching the numbers, that is the total for that plant as I was able to find multiple matching numbers from the two plants.
