- Joined
- Apr 21, 2026
- Threads
- 33
- Messages
- 261
- Reaction score
- 160
- Location
- LA
- Website
- www.facebook.com
- Vehicle(s)
- 2026 Tacoma TRD Sport
Hi, Jeremy from Mabett.
Two more Mabett lighting upgrades are now available for the 2024–2026 Tacoma: our Fang Lights and Side Marker Lights.
Fitment Details
Fang Lights (DRLs): 2024–2026 Tacoma SR, SR5, TRD PreRunner, TRD Sport, TRD Off-Road, Limited, Trailhunter and TRD Pro.
Side Marker Lights: 2024–2026 Tacoma TRD Sport, TRD Off-Road and Limited.
What Both Kits Have in Common?
Plug-and-Play
Both kits connect directly to the factory lighting system through the included harnesses, with no cutting or splicing of the factory wiring required.
The two Mabett kits also use matched wiring and signal logic, so they’re designed to work together. Some third-party lighting harnesses may use different control logic and could cause compatibility issues.
White Running Light + Amber Turn Signal
Both kits illuminate white during normal driving and switch to amber with the corresponding turn signal.
One-Year Warranty
Both products are backed by a one-year warranty. If you experience any quality-related issue within the first year, contact us for after-sales support.
Fang Lights (DRLs)
These replace the factory front fascia trim panels with new panels that have the lights built in, creating a cleaner, more integrated OEM+ look.
The black housing features four segmented white LED bars and an L-shaped amber section. There’s also a short flowing-light sequence at startup.
Side Marker Lights
These replace the original fender trim pieces and follow the factory fender contour for a cleaner, more integrated fit. They use OEM-style mounting clips, with no drilling or cutting required.
Quick Note: In accessory mode, low system voltage may cause the lights to flicker or behave irregularly. This was not observed once the engine was running normally.
Tacoma4G Launch Offer
Fang Lights (DRLs)
35% OFF, now $84.49
Use promo code 52FD9T2Z at checkout:
https://amzn.to/4dmemqb
Side Marker Lights
35% OFF, now $84.49
Use promo code HOLRPSS9 at checkout:
https://amzn.to/4rrkwLg
Questions or Feedback?
If you have any questions about fitment, installation, or running both kits together, feel free to leave a comment below. Get an extra 10% OFF when you join the Mabett 4th Gen Tacoma Garage
( Big thanks to @Will721 for sharing these photos! )
Fitment Details
Plug-and-Play
One-Year Warranty
Fang Lights (DRLs)
Side Marker Lights
Fang Lights (DRLs)
35% OFF, now $84.49
Side Marker Lights
35% OFF, now $84.49
