TRUMGETA
CHINA
Hey everyone,
We’ve been hard at work developing something that goes beyond just another pair of side steps. We’re excited to announce that starting this May, TRUMGETA will be launching our new line of Side Steps, featuring our exclusive, registered Auxchemic® Coating.
What is Auxchemic® Coating?
Our Auxchemic coating is a specialized, multi-stage industrial application process that creates a seamless, "armor-like" protective shell around the side steps.
It’s not just a layer of paint; it’s a high-performance barrier engineered for the harshest trail conditions.
Why Auxchemic Coating is a Game Changer for Your Rig:
  1. Seamless Waterproofing: Like a "seamless suit of armor," it completely seals the metal, preventing any water ingress or internal rust.
  2. Extreme Corrosion Resistance: Engineered to withstand salt, mud, and harsh chemicals—essential for those in the rust belt or frequent beach drivers.
  3. High Abrasion & Impact Resistance: This coating is built to take a beating. It’s incredibly tough against rock chips, trail debris, and heavy foot traffic.
  4. Flexible & Crack-Proof: Unlike traditional powder coating that can chip or crack under stress, the Auxchemic finish has high elasticity. It moves with the metal, ensuring the protection stays intact even under heavy impact.
  5. UV & Weather Endurance: Built for a long life cycle. It won’t fade or degrade under intense sun or extreme temperature swings.
Our goal was simple: to create a set of side steps that you don't have to worry about rusting out after a few seasons of salt and mud.
We want to hear from you!
We’re gearing up for the May launch, but before we do, we’d love to get the community's thoughts:
  • Have you used bedliner-coated gear on your truck before?
  • What’s the biggest issue you’ve had with traditional running board finishes?
  • Do you have any technical questions about the Auxchemic Coating process?
Drop your thoughts or questions below! We’re excited to chat and answer anything you want to know about this new tech.
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
My truck has OEM spray-on bedliner and rock rails. To make it easier to get in and out of the cab, I’ve put on N-Fab bolt-on steps. They are easy to remove so they don’t catch on bushes or ruts/rocks. They have rust on the edges and bolts so require periodic maintenance (rust rebonding or removal and painting).
Wondering if Trumgeta will just offer running boards or will you make a bolt-on step that would attach to rock rails or the truck frame. Having it coated to avoid rust would be an improvement over what I have.
Will721
Quad Cities
It would actually be rather easy to adapt your steps to bolt to the rock rails with a bit of time and a welder if they're steel. Just need to measure the diameter of the tube and buy a few of these:
Just trim your steps down and weld them to the lower half of a pair of lock collars. A drill press with the correct size hole saw will get you 90% of the way there. Of course you would need to re-paint afterwards anyway, but your paint is likely flaking due to poor prep work and quality paint from the manufacturer. It would be best to just strip them in a sand blaster, use a good quality primer and then paint or bedliner of your choosing.
G-Oil Guy
26 Tacoma Offroad
I’d love to see these from a few feet back. I hate the OEM predator steps and have been looking for replacements but I’m picky lol
lauren01
Lauren
Ventura, CA USA
They’re made of mild steel. I think the thin powder coat is coming off around the edges because of being blasted on dirt roads. That would be a cool project, but I don’t own welding gear… although Harbor Freight’s entry-level stuff has been on sale lately.
lauren01
Lauren
Ventura, CA USA
I hear you, I hate Predator steps with a passion. I hated them before I even thought of getting a truck again. I hated them when hating them wasn’t cool. 😂
G-Oil Guy
26 Tacoma Offroad
I love the rail/pinch weld protection aspect of their design but the step is too narrow and just way too far forward. They’d be 1000 times better if you could slide them on the rail to your desired spot.
Disclaimer: I know it’s not a real rail/frame slider. Just easier to refer to it as a rail.
lauren01
Lauren
Ventura, CA USA
One thing I like about DIY versions is that you can pick where you want them. My N-Fab steps only have one spot where they bolt on under each door area. What I like about them is that they are a 3 inch drop and the platform is 3 inches wide. It’s a good fit for my small feet (women’s 7.5) and wife’s clodhoppers (10.5).
TRUMGETA
TRUMGETA
CHINA
We are currently developing Auxchemic® running boards. These new side steps are a bolt-on design that attaches directly to the truck frame.
G-Oil Guy
26 Tacoma Offroad
TRUMGETA
TRUMGETA
CHINA
Will they work with the Trailhunter rock rails?
These won't work with the OEM rails as they both utilize the same frame mounting points. However, that’s a great suggestion—we’ll definitely keep it on our radar and take it into serious consideration for future product updates!
TRUMGETA
TRUMGETA
CHINA
Awesome to hear. Any approximate ETA?
We love the enthusiasm! We’re currently designing a brand-new running board series featuring our Patented Auxchemic® Armor. While we don't have a firm ETA just yet, stay tuned for updates.
I only ask because I’ve been eyeing these HARD and anything with improved material protection for the metal I am all for.
https://www.trumgeta.com/products/5-running-boards-for-2024-2025-toyota-tacoma-double-cab
It’s great to hear that material protection is your priority—that's exactly why we created the Auxchemic® coating. This style is indeed one of our top favorites, and we’re definitely taking your feedback to our R&D team!
G-Oil Guy
26 Tacoma Offroad
You make that exact same running board with that new coating and I’ll be there day 1 to buy.
