xipoqix_official
Jackie
China
Hey everyone,
When off-roading or driving on bumpy roads, do you often worry about your undercarriage getting scratched or, in severe cases, damaged?
The Engine Splash Shield is compatible with 2024 2025 2026 Tacoma. Fit both 2WD and 4WD models. ATTENTION: NOT fit hybrid models.
It protects key components such as the engine, oil pan, transmission bottom, and differential, reducing the impact of road debris like rocks on the undercarriage and lowering the risk of damage to core undercarriage components. It balances strength and weight to avoid bulkiness. The skid plate also features a drain hole, eliminating the need to remove the entire plate.
Made of high-quality carbon steel material, it features high strength, impact resistance and wear resistance. The structure is stable and does not deform easily. The surface features a powder-coated finish to enhance rust and corrosion resistance. Easy to install, with bolts can be installed directly.
Get yours here: https://www.amazon.com/dp/B0HG9CGT61
RutsyBucket
Hunter
Carlsbad, CA
2025 Terra Off Road
how do you pronounce the name of your brand?
Actually a decent looking piece of kit for the $$.
xipoqix_official
xipoqix_official
Jackie
China
Thanks! It's pronounced roughly "shee-poh-chee." The name is Xipoqix. If you're interested, feel free to check it out via the link above, and we'd love to hear your feedback!
TacoBirdinNW
2025 DCLB SR5
I put money on it not being much different than any of these.
Would be better off getting the Hardened steel landcruiser skid or trailhunter skid for $250 or the TRD aluminum skid for $310.
xipoqix_official
xipoqix_official
Jackie
China
Thank you for sharing your thoughts and the comparison. Our carbon steel skid plate offers great impact resistance and durability. A set is priced at $169.99. It's a great value for Tacoma owners looking to beef up their trucks.
