3 minute amber LED turn signal swap (no tools required)
Liquidassets
Bronson
Louisiana
2024 Tacoma TRD off-road
I just bought the lasfit switchback LED lights for the front turn signal and daytime running lights. I was surprised to see that toyota uses new body clips that don't require screwdrivers or extractor tools.
The driver's side was easier. You just twist the light housing counterclockwise about 90 degrees and it pops out. Twist it 90 degrees clockwise to put it back in.
The passenger's side requires you to remove the body clips holding the air intake in place. These are new body clips that I've never seen before. They have 3 settings (out, flush, and in). Push the middle of the clip in and it releases the clip. Do this for all 4 clips. Then find the turn signal housing and replace the bulb. Reset the body clips to the out setting and put into the holes. Push them down only to the flush setting.
I've uploaded some pictures but the website has a better how to video.
https://www.lasfit.com/products/202...ront-turn-signal-light&variant=45038489501943
Looks like there is a 30% off coupon on the homepage. (Nonaffiliate)
2024 Tacoma 3 minute amber LED turn signal swap (no tools required) PXL_20240721_213744475.MP
2024 Tacoma 3 minute amber LED turn signal swap (no tools required) PXL_20240721_213737370.MP~2
2024 Tacoma 3 minute amber LED turn signal swap (no tools required) PXL_20240721_213844918.MP
2024 Tacoma 3 minute amber LED turn signal swap (no tools required) PXL_20240721_213842803.MP
2024 Tacoma 3 minute amber LED turn signal swap (no tools required) PXL_20240721_213849459.MP
2024 Tacoma 3 minute amber LED turn signal swap (no tools required) PXL_20240721_213925948.MP
2024 Tacoma 3 minute amber LED turn signal swap (no tools required) PXL_20240721_213806615.MP
2024 Tacoma 3 minute amber LED turn signal swap (no tools required) PXL_20240721_213803291.MP~2
Ticka
2024 Tacoma TRD-Sport
Just swapped mine out with the Lasfit LEDs. Super easy and I agree that the clips were great. No tools and just a few minutes.
Sner
I switched mine as well, they were in on sale for prime day. I bought the switchbacks, impressive at night you can see the amber signal reflecting in the road, they are really bright, would never see that with an incandescent bulb.
LASFIT
Ontario. California
www.lasfit.com
Toyota Tacoma 2024
Thank you so much for sharing the installation process of the T3-7443D LED bulb! The details in your post, like twisting the light housing counterclockwise about 90 degrees, were actually more thorough than in the video. We really appreciate your detailed sharing! :D
