braaadyyota
Brady
Minnesota
linktr.ee
Hello everyone! Maybe some of you have seen this “quick guide”, as I’m calling it.
The first part is just a handful of common questions and issues people have brought up frequently. The second part is a list of vendors, a link to their site and bullet points of what they sell.
Please let me know if you think any questions, issues(with straightforward fixes), or vendors should be added to this, link is down below. Also, here’s a photo of my TRD OR, Thanks!
2024 Tacoma 4th Gen Tacoma Quick Reference Guide Thread! đź“’ IMG_0061
4th Gen Toyota Tacoma Quick Guide
4th Gen Toyota Tacoma(2024+) Quick Guide
COMMON QUESTIONS
What Oil Weight & Filter?
0W-20 Full Synthetic
Toyota Oil Filter PN: 90915-YZZN1
How do I turn off the seatbelt chime?
Your dealer might program this setting out for you, unlikely though.
Use an OBD2 scanning/programming tool such as Carista or Carly, with this you can change or customize a variety of settings & features.
How do I completely turn off traction control?
While fully stopped, hold the traction control on/off button on the button panel to the left of the steering wheel.
How do I remote start my Tacoma?
Toyota App: In your Toyota app, make sure all doors are closed and locked. Hold down the round “Start” button on the Remote page of the app.
Key Fob: Quickly press lock 3 times, on the 3rd time, hold the lock button down.
Turning off the rear seat reminder?
Go to settings in the instrument panel, turn off the back seat reminder.
Whistling noise after removing air dam
4 plugs must be inserted into the bottom holes on lower control arm. Google search this to find forum with alternate plugs.There are several cheaper options
Toyota Hole Plug PN: 90950-A1021
Amazon plug alternative: Plastic Plugs
What tire size fits?
Use this as a reference guide, not a guarantee. Please research your exact setup including tire size, wheel size(diameter, width, offset) as well as level/lift height. Tire type may play a factor as well.
Tire SizeWheelsRubbing?Modifications Needed
33s (285/70/17r)StockNNone
AftermarketAftermarketLikely noneLikely none
34s (285/75/17, 305/70/17, 295/70/17)StockLittle to noneMay need to remove crash bracket and/or mudflaps
AftermarketAftermarketLittle to noneLevel/Lift. May need to remove crash bracket and/or mudflaps
35s (35x12.5R17)StockWill likely rub. Lift is recommendedLift
AftermarketAftermarketWill likely rub. Lift is recommendedLift plus crash bracket/mud flap removal. May need to do extra trimming.
Higher offset wheels will cause more interference with body.
Links to wheel/tire fitment gallery and videos:
Custom Offsets 2024+ Tacoma Gallery
2024 Tacoma Wheel Offset & Tire Size Guide | FULL CYCLE TEST #2024Tacoma #toyotatacoma2024
Maximum Tire Size For 2024 Tacoma WITHOUT Lift Kit!
ReadyLIFT Tire Fitment on a Leveled 2024 Toyota Tacoma
ISSUES
Squeak during startup
This is related to the AC starting(likely the belt). Seems to be nothing to worry about, see dealer if it is a concern.
Glove box door gap
It is designed to have play in the glove box if passengers knees contact the door.
Link to glove box gap fix: https://printdrivendesigns.etsy.com/listing/1814139431
Front shock mount top hat blown out
Uncommon issues that has happened to a handful of people.
No known fix prevention from Toyota.
Icon sells a top hat reinforcement plate: 2024 Tacoma Icon Coilover Top Plate Reinforcement Kit
________________________________________
4th Gen Tacoma Accessories
Lasfit Liners & Auto Lighting
Website Link: Lasfit Liners & Auto Lighting
Offered Products
  • Led light bulbs
    • Forward Lighting(high & low beams, fog lights, turn signals, etc.)
    • Reverse, license plate lights & more
  • Interior floor mats
  • Truck bed mats
  • Tire inflators
  • Off road lights, mounting brackets, switch panels & accessories
Diode Dynamics
Website Link: Diode Dynamics
Offered Products
  • Off road lights
    • LED Light Bars
    • LED Pod lights
    • Brackets & Kits
    • ATV/UTV Kits
    • Hitch Mount Lights
    • Rock Lights
    • Other accessories
  • LED lamp upgrades
    • Headlights
    • Side markers
    • Turn signals
    • Fog lamps
  • LED Light Bulbs
    • Tail Lights
    • Backup, cargo, license plate & 3rd brake light
    • Interior
  • Accent lighting, LED Modules & other lighting accessories
TripleAliners
Website Link:TripleAliners
Amazon Link: Amazon: TripleAliners
Offered Products
  • Truck bed mats
Cornfed Suspension
Website Link: Cornfed Suspension
Offered Products
  • Suspension lift & leveling kits
  • Recovery points(D-ring shackle & soft shackle)
SXTH Element
Website Link: SXTH Element
Offered Products
  • Trail exhaust pipe
  • Intake
  • Recovery points
  • Rear seat delete Mille panel
  • Throttle controller
  • Ditch light brackets
  • Ignition coils
  • Roof rack
Cali Raised LED
Website Link: Cali Raised LED
Offered Products
  • Rock Sliders
  • Bed/Roof Racks
  • Molle Systems
  • LED mount kits
  • Interior accessories
  • Exterior accessories
  • OEM switches & control panels
Westcott Designs
Website Link: Westcott Designs
Offered Products
  • Bed racks
  • Roof racks
  • Rock sliders
  • Preload collar lift & leveling kits
  • Bed stiffeners
Rogue Offroad
Website Link: Rogue Offroad
Offered Products
  • Suspension components(lift kits, springs, shocks, control arms, links)
  • Offroad armor
  • Rock sliders & side steps
  • Bed racks
  • Roof racks
  • Bed Covers
  • Performance accessories
Dongar Technologies
Website Link: Dongar Tech
Offered Products
  • Dash cam kits
  • Dash cam power adapters
Baja Designs
Website Link: Baja Designs
Offered Products
  • Light Bars
  • Pod Lights
  • Ditch Lights & Ditch light kits
  • Reverse lights
  • Light control panels
Peak Suspension
Website Link: Peak Suspension
Offered Products
  • Lift kits
  • Leveling kits
  • Upper control arms
  • Bed bars & racks
  • Front bumpers
  • Roof racks
Icon Vehicle Dynamics
Website Link: Icon Vehicle Dynamics
Offered Products
  • Suspension Systems
  • Shocks
  • Coil Springs & Spacers
  • Driveline Components
  • Bump Stops
  • Off road armor
  • Control Arm
Billie Bars
Website Link: Billie Bars
Offered Products
  • Tonneau cover compatible bed racks & bars
  • Tailgate Covers
  • Molle panels
  • Bike, watersports & snowsports rack attachments
  • Awnings
KB Voodoo
Website Link: KB Voodoo
Offered Products
  • Modular bed racks
  • Accessories & Storage
Kuat
Website Link: Kuat
Offered Products
  • Truck bed racks
  • Roof racks
  • Ski & snowboard racks
  • Bike racks
  • Hitch bike racks
ScreenProtech
Website Link: ScreenProtech
Offered Products
  • Screen protectors(infotainment, instrument cluster, climate controls, shifter, etc.)
OnlyAutoFans
Website Link: OnlyAutoFans Merch
Offered Products
  • OnlyAutoFans Merch(4Runner, Tacoma, Tundra)
Wheel Companies
Method Race Wheels
KMC Wheels
Lock Offroad Wheels
Fitapaldi Offroad
SCS Wheels
Relations Race Wheels
SSW Wheels
Black Rhino Wheels
Fuel Wheels
Raceline
Icon
Vision
Tonneau Covers
REALTRUCK
Radco
Access
Diamondback
Amazon - Please search forums or read reviews to ensure fit
Mud Flaps
OEM:
Standard OEM
76622-AK010(Driver Front)
76626-AK010(Driver Rear)
76621-AK010(Passenger Front)
76625-AK010(Passenger Rear)
Canadian OEM
PK389-35R00-P1 - Wider than factory, works with SR & SR5 w/o wider fender flares
PK389-35R50-P1 - Works with TH & Pro fender flares
Aftermarket:
ARK - Micro, full size, inner fender splash guard
RokBlokz - High clearance, rally, window vents
Tufskinz - Slightly larger than OEM
RallyArmor - Rally style
Rek Gen - Off road XL
saerandy
Randy
Virginia
2024 SR5
braaadyyota
braaadyyota
Brady
Minnesota
linktr.ee
I think a good link under "What size tire fits" would be this one. It's a great site that shows actual pics of the 2024 and 2025's with actual wheel and tire sets so you can see what your truck might look like. It looks like users are adding pics frequently and it was (for me) a great way to visualize things. Plus you can filter by lift, rubbing, stock, etc.
[ https://www.customwheeloffset.com/w...l=Tacoma&drive=4WD&suspension=All&rubbing=All ]
Excellent! I’ll add that in there. Thank you for the recommendation.
saerandy
Randy
Virginia
2024 SR5
While I'm thinking about it, there are tons of posts about the OEM mud flaps for these trucks. Typical stock flaps in the US (when installed) are $60 on the window sticker and really don't provide a lot of coverage. See this post. In summarizing all the posts it looks like Toyota has at least three different mud flaps for the Tacoma. The first one I mentioned. A second one (PK389-35R00-P1) is wider and works for the SR & SR5 without the 'bolt-on' flare you see on higher trim levels. The third (PK389-35R50-P1) is as wide as the bolt-on flare (TH, Pro, etc).
The last two are sold in sets of 4 from the dealer and seem to be made in Canada prompting many members to refer to them as the "Canadian Mud Flaps".
braaadyyota
braaadyyota
Brady
Minnesota
linktr.ee
Oh interesting. I was completely unaware of that many different mud flaps but it makes sense. I can add those in there as well. I’ll maybe add it into the common questions section and refer to the vendor list for aftermarket ones as well.
Bannedname
US, Missouri
Tesla Model 3
Happen to know of a picture comparison anywhere?
I just installed the pk389-35r00-p1 to replace the original US mud flaps. Without a level/lift they required trimming on 17x8.5 +25 wheels with a 33
saerandy
Randy
Virginia
2024 SR5
What did you have to trim? There are some pics in this thread but if you look around there are 3-4 mudflap posts on here some of which have pics.
fightforfood247
Matt
Syracuse ny
2024 Tacoma trd off road
Damn so of all the things I’ve seen. This is gots be one of the coolest, to take the time out and make this for people. That’s def badass brotha and going to help alot of peeps out. Props for real
braaadyyota
braaadyyota
Brady
Minnesota
linktr.ee
Thank you so much. I truly appreciate the kind words. It really started out because I see so many of the same questions posted in Facebook groups and evolved. This helping people out is my goal! I hope it can keep growing as people have more questions and issues(hopefully not).
I also like this list. As more people discover it, it'll grow. I have a few ideas to add.
braaadyyota
braaadyyota
Brady
Minnesota
linktr.ee
Thanks! Feel free to message me or just shout them out in here when you think of them!
Bannedname
US, Missouri
Tesla Model 3
There is a section that extends into the wheel area that is not on the original USDM mudflaps. I cut the CDM ones to be flush like the USDM ones.
braaadyyota
braaadyyota
Brady
Minnesota
linktr.ee
Updated: Added OEM and several sets of aftermarket mud flaps.
If there are any aftermarket mud flaps I should add, lmk. Thanks for the suggestion @saerandy!
nurp42
TRD PreRunner
Jeff
'24 PreRunner
OP, thanks so much for posting this info----very helpful(y)
